Replace font_5x4.h library with font.h for 8x8 larger charcaters, reference help
I’m playing with Sure P4 32X8 LED panels, running the sample sketch located at http://scuola.arduino.cc/en/content/interfacing-arduino-uno-sure-electronics-led-dot-matrix-based-ht1632c-controller .
The font_5x4.h library is working, but I’d like to have a 8x8 font, and I found the font.h library that seems to have the 8x8 font size.
I’m not quite able to understand what references I would change to use the font.h library. The font_5x4.h library has Height and Width references, but the font.h library does not.
Any assistance appreciated.
My code is:
#include <font.h>
#include <font_5x4.h>
#include <HT1632.h>
#include <images.h>
int i = 0;
int wd;
void setup () {
  // Setup and begin the matrix
  // HT1632.begin(CS1,WR,DATA)
  HT1632.begin( 9, 10, 11);
  // Give the width, in columns, of the assigned string
  // FONT_5x4_WIDTH and FONT_5x4_HEIGHT are parameter specified in the "font_5x4.h" file
  wd = HT1632.getTextWidth("SCROLLING MESSAGE TEST", FONT_5X4_WIDTH, FONT_5X4_HEIGHT);
void loop () {
  // Font rendering example
  HT1632.drawTarget(BUFFER_BOARD(1));
  HT1632.clear();
  HT1632.drawText("SCROLLING MESSAGE TEST", 2*OUT_SIZE - i, 2, FONT_5X4, FONT_5X4_WIDTH, FONT_5X4_HEIGHT, FONT_5X4_STEP_GLYPH);
  HT1632.render();
  i = (i+1)%(wd + OUT_SIZE * 2);
  delay(200);
have find any method to generate personalized large font ?
i attach actual converted font.
font_7x6.h (3.89 KB)
font_8x4.h (5.11 KB)
