Hi all,
I'm building an instrument that I want to collect a water sample every 2 hours via a series of 12 solenoid valves. Drawing from info from this tutorial: Controlling 16 channel relay module using Arduino - Robojax I've written a sketch using a for loop that basically does what I want it to do:
//Copy of saved sketch that currently works
#include <Time.h>
#include <TimeLib.h>
#include <TimeAlarms.h>
int pumpPin = 2; // pin controlling the pump relay
int endvalvePin = 3; //pin controlling the end valve relay
int samplevalvePin[12] = {4, 5, 6, 7, 8, 9, 10, 11, 12, A0, A1, A2}; //relays controlling sample valves
pinMode(pumpPin, OUTPUT);
pinMode(endvalvePin, OUTPUT);
pinMode(samplevalvePin, OUTPUT);
setTime(12, 59 , 50, 13, 3, 2019); // H, M, S, d, m, Y
Serial.println("MIMS Sample Collection");
if (minute() % 15 == 0) { //starts loop at top of the hour
Serial.println("Begin Program"); digitalClockDisplay();
sampleProgram();
Serial.print("Delay Program "); digitalClockDisplay();
delay(5000);
return;
Serial.print("Sampling Complete");
exit(0);
void sampleProgram() {
for (int i = 0; i < 12; i++)
Serial.print("End Valve Open "); digitalClockDisplay();
digitalWrite(endvalvePin, HIGH); //Open end valve
digitalWrite(pumpPin, HIGH); //Turn on pump
Serial.println("Pump On, System flushing");
//Serial.println("System flushing");
delay(1000); //Allow pump to flush out system
Serial.println("End Valve Closed");
digitalWrite(endvalvePin, LOW); //Close end valve to allow for sample collection
//Serial.print("Sample Valve "); Serial.print(i+1); Serial.println(" Open");
Serial.print("Sample Collection "); Serial.print(i + 1); Serial.println(" Begin");
digitalWrite(samplevalvePin[i], HIGH); //Open valve for sample collection
//Serial.print("Sample "); Serial.print(i+1); Serial.println(" Start");
delay(1000); //amount of time that it takes to flush vials and fill them
Serial.print("Sample Collection "); Serial.print(i + 1); Serial.println(" End");
digitalWrite(samplevalvePin[i], LOW); //Close sample collection valve
//delay(500);
Serial.println("End Valve Open");
Serial.println("System flushing...");
digitalWrite(endvalvePin, HIGH); //Close end valve
Serial.println("Pump Off");
digitalWrite(pumpPin, LOW); //Turn off pump
Serial.print("Sample Number "); Serial.print(i + 1); Serial.println(" Complete");
void digitalClockDisplay() {
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(year());
Serial.print("-");
Serial.print(month());
Serial.print("-");
Serial.print(day());
void printDigits(int digits) {
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if (digits < 10)
Serial.print('0');
Serial.print(digits);
This for loop opens and closes all valves and runs the pump at the specified times, basic ally doing what I want it to do (delays are shortened for testing purposes). However, I need to add a proper delay so that samples are collected every 2 hours. After perusing some other threads on the topic I came across one that seemed to be similar to what I need to do Topic: Replace delay with millis () within "for loop". Upon reading this thread I realized that a for loop within loop() is bad practice (I'm a newcomer to c++). As such, I've tried to remove my original for loop and add the delay using millis() but now the program won't complete:
//Version of working sketch trying to replace pieces of for loop (i)
//to work with non-delay timer
#include <Time.h>
int Sample = 12;
if (minute() % 60 == 0) { //Start program at top of the next hour
Serial.print("Begin Program "); digitalClockDisplay();
static unsigned long _timer = millis();
static int Sample = 1;
if ((millis() - _timer) >= 5000) //Delay will eventually be for 2 hours
_timer = millis();
sampleCollection(Sample); //Sample collection function
if (++Sample > 12)
Sample = 1;
delay(5000);
return;
//while(!Serial);
exit(0);
void sampleCollection(int Sample) {
//Serial.print("Sample Collection "); Serial.print(i + 1); Serial.println(" Begin");
digitalWrite(Sample, HIGH); //Open valve for sample collection
//Serial.print("Sample Collection "); Serial.print(i + 1); Serial.println(" End");
digitalWrite(Sample, LOW); //Close sample collection valve
//delay(500);
digitalWrite(endvalvePin, HIGH); //Open end valve to flush system
Serial.print(" ");
Serial.print("-");
Serial.print("-");
Serial.print(":");
if (digits < 10)
Serial.print('0');
Any thoughts on what I may be missing here? Like I said I'm new to Arduino and c++ although I'm well-versed in other languages. Thanks in advance!
