Replace remote Chacon by arduino and HomeEasy
I would like replace my remote DI-O by chacon ref 54760 by Arduino with lib HomeEasy
http://playground.arduino.cc/Code/HomeEasy
I have 2 arduino Uno with RF transmission Kit 433Mhz
http://www.evola.fr/product_info.php/kit-transmission-433mhz-compatible-arduino-p-162
Modulation ASK are the same like the remote Chacon.
I tested the 2nd script "AM-HRR3 receiver test" and here are the results
When I press button 1 ON on remote Chacon:
Sender 11833462
No group
On
Recipient 0
When I press button 1 OFF :
Sender 11833462
No group
Off
Recipient 0
the button 2 correspond with recipient 1 and the button 3 with recipient 2.
Now I would like to remove the remote and issue codes with arduino. I tested this script "HE300 Automatic Protocol Transmitter 'Simulator' "
I have question:
  • I have replace HE Address 272946 in example by my device 11833462 but I don't understand where I can precise recipient and status On or Off in script? Where I can change it? I want turn off button 2 for example?
Thank you!
 * HE300 Automatic Protocol Transmitter 'Simulator'
 * This demo code emits a homeeasy automatic protocol ON message
 * then 3 seconds later, an off message
 * You dont need to learn the Arduino into the socket, because it can
 * pretend to be a transmitter you already have.
 * Use the Automatic protocol reciever code above to find out
 * your transmitter address 8-)
 * *Only* tested with one HE300 transmitter (HE Address 272946) with its
 * slider switch set to 1 which appears to be 0 in fact.
 * Seems to work with a switch socket (HE302S) and can turn it on and off
 * without the ardunio being learned into the socket.
 * Martyn Henderson 02/10/2009  http://martgadget.blogspot.com
 * Cheers to Barnaby and Peter, because without the code above
 * that shows the receiver output this wouldnt have been possible!
 * If you make something cool using HomeEasy and Arduino, please
 * post back here with a link to your code so we can all enjoy.
bool bit2[26]={};              // 26 bit global to store the HE device address.
int txPin = 2;                 // 433mhz transmitter on pin2
  pinMode(txPin, OUTPUT);      // transmitter pin.
  Serial.begin(9600);         // console port
  Serial.println("go");
  itob(11833462,26);            // convert our device code..
  transmit(true);            // send ON
  delay(10);                 // wait (socket ignores us it appears unless we do this)
  transmit(true);            // send ON again
  delay(3000);               // wait 3 sec
  transmit(false);           // and off again.
  delay(10);
  transmit(false);
  Serial.println("stop");    // done.
  // we dont use the arduino loop, this is a one-shot transmit in this example.
void transmit(int blnOn)
  int i;
  // Do the latch sequence..
  digitalWrite(txPin, HIGH);
  delayMicroseconds(275);     // bit of radio shouting before we start.
  digitalWrite(txPin, LOW);
  delayMicroseconds(9900);     // low for 9900 for latch 1
  digitalWrite(txPin, HIGH);   // high again
  delayMicroseconds(275);      // wait a moment 275
  digitalWrite(txPin, LOW);    // low again for 2675 - latch 2.
  delayMicroseconds(2675);
  // End on a high
  // Send HE Device Address..
  // e.g. 1000010101000110010  272946 in binary.
  for(i=0; i<26;i++)
    sendPair(bit2[i]);
  // Send 26th bit - group 1/0
  sendPair(false);
  // Send 27th bit - on/off 1/0
  sendPair(blnOn);
  // last 4 bits - recipient   -- button 1 on the HE300 set to
  // slider position I in this example:
  sendPair(false);
  sendPair(false);
  sendPair(false);
  sendPair(false);
  digitalWrite(txPin, HIGH);   // high again (shut up)
void sendBit(boolean b) {
  if (b) {
    delayMicroseconds(310);   //275 orinally, but tweaked.
    delayMicroseconds(1340);  //1225 orinally, but tweaked.
  else {
void sendPair(boolean b) {
  // Send the Manchester Encoded data 01 or 10, never 11 or 00
  if(b)
    sendBit(true);
    sendBit(false);
  sendBit(false);
  sendBit(true);
void itob(unsigned long integer, int length)
{  //needs bit2[length]
  // Convert long device code into binary (stores in global bit2 array.)
 for (int i=0; i<length; i++){
   if ((integer / power2(length-1-i))==1){
     integer-=power2(length-1-i);
     bit2[i]=1;
   else bit2[i]=0;
unsigned long power2(int power){    //gives 2 to the (power)
 unsigned long integer=1;
 for (int i=0; i<power; i++){
   integer*=2;
 return integer;
I have found it
It's here
  sendPair(false);
  sendPair(false);
  sendPair(false);
  sendPair(false);
Hii,
Did you manage to get it working? I bought my DIO today but coding with the 434mhz module is very hard.
Is it possible to share the code you have...
Thanks
Tim
timothygravestein@gmail.com
