replace stm08 with arduino (PWM)
over and over again, stupid questions from a beginner :slight_smile: :slight_smile: :slight_smile:
because of an error, the mpu power supply that I used was damaged, and I intend to replace it with Arduino Pro Mini 16MHz.
the power supply that i use is using stm08 MPU and mp2307 as voltage regulator which works at 340khz frequency (according to what i read on the datasheet).
my question is:
# does mp2307 really use 340khz frequency?
# if yes, can atmega 328 be able to issue such a large frequency?
# because according to my knowledge as a beginner, Is not that atmega 328 only issued a maximum frequency of 62khz?
I have tried to make a circuit using Arduino Pro Mini as a substitute for STM08, removing all components in the red box, input PWM connected from the green point but the output voltage looks unstable, down and up erratically, because I believe the frequency for the mp3207 drive does not match the frequency produced by Arduino.
the code that I made to generate pwm using arduino
TCCR0B = TCCR0B & B11111000 | B00000010;// for PWM frequency of 62500.00 Hz
pinMode(5, OUTPUT);
 analogWrite(5,88);
THANK YOU
MP2307.pdf (697 KB)
Yes
Yes. Change the pre scaler value in the timer you want to use.
Bad idea, switched mode power supplies are complex systems and are not very suitable for emulating with a CPU. It is hard enough to get the layout correct with a dedicated chip without making it more complex than it need be.
I really appreciate your attention, now i am looking for information about building 340khz frequency.
THANK YOU
