replace()
Hi.
I have this project where I use split() and replace().
Now I have a bad feeling that I can’t use char* split() and replace() togehter.
code:
#include <string.h>
  Serial.begin(19200);
void loop(){
char test[] = "s1: 22, s2: 43, s3: 12, s4: 56";
test = test.replace(' ', '');
char *token = strtok(test, ",");
int i = 1;
while(token)
{  // Do something with this word
Serial.print(token);
token = strtok(NULL, ",");
i +=1;
Cause I get this error message:
split:8: error: request for member ‘replace’ in ‘test’, which is of non-class type ‘char [31]’
Anny way to solve this?
-Andy
You can not call methods on variables of scalar datatypes. You need to look for some c-style function for replacing chars in a c-string. If you're up for the challenge, you could write your own replace function :)
Perhaps, the use of char *token = strtok(test, " ,"); and token = strtok(NULL, " ,"); (note: " ," instead of ",") might solve your problem without removing the blanks (if this is intended by replace(' ', '')).
Oliver
Test is an array of char, not a class with member functions, therefor the replace() is not existant => compiler error
From the code I see you want to remove the spaces, you can use an inplace remove like below
#include <string.h>
  // test = test.replace(' ', '');
    Serial.println(test);
  remove(test, ' ');
  int i = 1;
  while(token)
    i +=1;
void remove(char *str, char r)
  char *p, *q;
  p = q = str;
  while (*p != '\0')
    while (*p == r) p++;
    *q++ = *p++;
  *q = '\0';
Sweet robtillaart. Thanks for your help :) It works!
Now I'm just implent in my own code...
-Andy
