replacing a hbridge l298 with a roboclae
hi
io have this osoyoo code (below). i want to replace the std H bridge l298 motor driver with a much powerful roboclaw 30a. i have to change the way the Arduino mega communicates with the dirver. need help with amending the osoyoo code to accommodate the new serial communication used with roboclaw. is there a quck
code to replace in the osoyoo supplied code?
thanks
the osoyoo code
/*  ___   ___  ___  _   _  ___   ___   ____ ___  ____
 * / _ \ /___)/ _ \| | | |/ _ \ / _ \ / ___) _ \|    \
 *| |_| |___ | |_| | |_| | |_| | |_| ( (__| |_| | | | |
 * \___/(___/ \___/ \__  |\___/ \___(_)____)___/|_|_|_|
 *                  (____/
 * Arduino Mecanum Omni Direction Wheel Robot Car
 * Tutorial URL http://osoyoo.com/?p=30022
 * CopyRight www.osoyoo.com
 * After running the code, smart car will
 * go forward and go backward for 2 seconds,
 * left turn and right turn for 2 seconds,
 * right shift and left shift for 2 seconds,
 * left diagonal back and right diagonal forward for 2 seconds,
 * left diagonal forward and right diagonal back for 2 seconds,
 * then stop.
#define SPEED 140
#define TURN_SPEED 160
#define speedPinR 9   //  Front Wheel PWM pin connect Right MODEL-X ENA
#define RightMotorDirPin1  22    //Front Right Motor direction pin 1 to Right MODEL-X IN1  (K1)
#define RightMotorDirPin2  24   //Front Right Motor direction pin 2 to Right MODEL-X IN2   (K1)
#define LeftMotorDirPin1  26    //Front Left Motor direction pin 1 to Right MODEL-X IN3 (K3)
#define LeftMotorDirPin2  28   //Front Left Motor direction pin 2 to Right MODEL-X IN4 (K3)
#define speedPinL 10   //  Front Wheel PWM pin connect Right MODEL-X ENB
#define speedPinRB 11   //  Rear Wheel PWM pin connect Left MODEL-X ENA
#define RightMotorDirPin1B  5    //Rear Right Motor direction pin 1 to Left  MODEL-X IN1 ( K1)
#define RightMotorDirPin2B 6    //Rear Right Motor direction pin 2 to Left  MODEL-X IN2 ( K1)
#define LeftMotorDirPin1B 7    //Rear Left Motor direction pin 1 to Left  MODEL-X IN3  (K3)
#define LeftMotorDirPin2B 8  //Rear Left Motor direction pin 2 to Left  MODEL-X IN4 (K3)
#define speedPinLB 12    //  Rear Wheel PWM pin connect Left MODEL-X ENB
/*motor control*/
void go_advance(int speed){
   RL_fwd(speed);
   RR_fwd(speed);
   FR_fwd(speed);
   FL_fwd(speed);
void go_back(int speed){
   RL_bck(speed);
   RR_bck(speed);
   FR_bck(speed);
   FL_bck(speed);
void right_shift(int speed_fl_fwd,int speed_rl_bck ,int speed_rr_fwd,int speed_fr_bck) {
  FL_fwd(speed_fl_fwd);
  RL_bck(speed_rl_bck);
  RR_fwd(speed_rr_fwd);
  FR_bck(speed_fr_bck);
void left_shift(int speed_fl_bck,int speed_rl_fwd ,int speed_rr_bck,int speed_fr_fwd){
   FL_bck(speed_fl_bck);
   RL_fwd(speed_rl_fwd);
   RR_bck(speed_rr_bck);
   FR_fwd(speed_fr_fwd);
void left_turn(int speed){
   RL_bck(0);
   RR_fwd(speed);
   FR_fwd(speed);
   FL_bck(0);
void right_turn(int speed){
   RL_fwd(speed);
   RR_bck(0);
   FR_bck(0);
   FL_fwd(speed);
void left_back(int speed){
   RL_fwd(0);
   RR_bck(speed);
   FR_bck(speed);
   FL_fwd(0);
void right_back(int speed){
   RL_bck(speed);
   RR_fwd(0);
   FR_fwd(0);
   FL_bck(speed);
void clockwise(int speed){
   RL_fwd(speed);
   RR_bck(speed);
   FR_bck(speed);
   FL_fwd(speed);
void countclockwise(int speed){
   RL_bck(speed);
   RR_fwd(speed);
   FR_fwd(speed);
   FL_bck(speed);
void FR_fwd(int speed)  //front-right wheel forward turn
  digitalWrite(RightMotorDirPin1,HIGH);
  digitalWrite(RightMotorDirPin2,LOW);
  analogWrite(speedPinR,speed);
void FR_bck(int speed) // front-right wheel backward turn
  digitalWrite(RightMotorDirPin1,LOW);
  digitalWrite(RightMotorDirPin2,HIGH);
void FL_fwd(int speed) // front-left wheel forward turn
  digitalWrite(LeftMotorDirPin1,HIGH);
  digitalWrite(LeftMotorDirPin2,LOW);
  analogWrite(speedPinL,speed);
void FL_bck(int speed) // front-left wheel backward turn
  digitalWrite(LeftMotorDirPin1,LOW);
  digitalWrite(LeftMotorDirPin2,HIGH);
void RR_fwd(int speed)  //rear-right wheel forward turn
  digitalWrite(RightMotorDirPin1B, HIGH);
  digitalWrite(RightMotorDirPin2B,LOW);
  analogWrite(speedPinRB,speed);
void RR_bck(int speed)  //rear-right wheel backward turn
  digitalWrite(RightMotorDirPin1B, LOW);
  digitalWrite(RightMotorDirPin2B,HIGH);
void RL_fwd(int speed)  //rear-left wheel forward turn
  digitalWrite(LeftMotorDirPin1B,HIGH);
  digitalWrite(LeftMotorDirPin2B,LOW);
  analogWrite(speedPinLB,speed);
void RL_bck(int speed)    //rear-left wheel backward turn
  digitalWrite(LeftMotorDirPin1B,LOW);
  digitalWrite(LeftMotorDirPin2B,HIGH);
void stop_Stop()    //Stop
  analogWrite(speedPinLB,0);
  analogWrite(speedPinRB,0);
  analogWrite(speedPinL,0);
  analogWrite(speedPinR,0);
//Pins initialize
void init_GPIO()
  pinMode(RightMotorDirPin1, OUTPUT);
  pinMode(RightMotorDirPin2, OUTPUT);
  pinMode(speedPinL, OUTPUT);
  pinMode(LeftMotorDirPin1, OUTPUT);
  pinMode(LeftMotorDirPin2, OUTPUT);
  pinMode(speedPinR, OUTPUT);
  pinMode(RightMotorDirPin1B, OUTPUT);
  pinMode(RightMotorDirPin2B, OUTPUT);
  pinMode(speedPinLB, OUTPUT);
  pinMode(LeftMotorDirPin1B, OUTPUT);
  pinMode(LeftMotorDirPin2B, OUTPUT);
  pinMode(speedPinRB, OUTPUT);
  stop_Stop();
  init_GPIO();
go_advance(SPEED);
     stop_Stop();
go_back(SPEED);
      stop_Stop();
left_turn(TURN_SPEED);
      stop_Stop();
right_turn(TURN_SPEED);
     stop_Stop();
right_shift(200,200,200,200); //right shift
     stop_Stop();
left_shift(200,200,200,200); //left shift
     stop_Stop();
left_shift(200,0,200,0); //left diagonal back
     stop_Stop();
right_shift(200,0,200,0); //right diagonal ahead
     stop_Stop();
left_shift(0,200,0,200); //left diagonal ahead
     stop_Stop();
right_shift(0,200,0,200); //right diagonal back
     stop_Stop();
void loop(){
the std roboclaw code is
//Includes required to use Roboclaw library
#include <SoftwareSerial.h>
#include "RoboClaw.h"
//See limitations of Arduino SoftwareSerial
SoftwareSerial serial(10,11);
RoboClaw roboclaw(&serial,10000);
#define address 0x80
  //Open roboclaw serial ports
  roboclaw.begin(38400);
  roboclaw.ForwardM1(address,127); //start Motor1 forward at half speed
  roboclaw.BackwardM2(address,127); //start Motor2 backward at half speed
