replacing a lower resolution DAC with a higher resolution DAC
i have an application circuit board with 6 bit dac TDA8444, but the problem is this DAC is really old and it is not available.
i have found an alternative LTC2637-8 but it is 8 bit
LTC2637
TDA8444
can i use a higher resolution 8 bit instead of 6 bit?
Thanks in advance
Yes. You will need to send this new chip different numbers than you did the old one but it will work when you send them the right ones.
