i made automatic color changer which is fitted into one of the taps in my house composing of lm35 temperature sensor .
if temperature of water is < 25 color of water seems blue >40 hot or else green.
i have used arduino for this.
now as arduino seems not feasible to be kept near the tap for this specific work and needed for another of my works .
what measure should i take to replace arduino with cheaper alternative.
This is not a specific question.
what a person should do after prototyping to bring the successfully prototyped product into the market.
Arduino is not a good option.Because his project must not cost beyond threshold limit.
There is no general solution for non-specific scenarios. You can build a "standalone Arduino", use smaller AVR chips like the 84s or 85s, or you could use discrete/passive components. What should be done will depend on the scenario.
i can use opamp as a comparator..
but i dont want the answers in high..or low..
my lights intensities varies with temp.
also..
lm35 have such a low precision that.. using it in the comparator is not feasible for long run as voltage of the batteries goes on decreasing
and lm 35 give values in millivolts.
"if temperature of water is < 25 color of water seems blue >40 hot or else green"
batteries, well yes , they do have voltage change over time, but the correct circuit takes care of that.
LM35 in mV, yes, but op amps provide gain, so no problem.
I'd suggest that the arduino analog input might benefit from an amp between the LM35 and the Arduino , possibly with a bit of filtering any way.
out of interest, how u going to charge the battery ?
There is no reason why you can't use a Tiny85 and an RGB LED. THe 85 has an analog channel or two, can do PWM on 3 ports... Here is an example of a Tiny that I have running on my desk...
//ATtiny85 RGB color fading Mood Light NOW WITH LIGHT SENSING CAPABILITIES!!!
const int redPin = 0;
const int grnPin = 1;
const int bluPin = 2;
const int sensor = 3; // Ground for continous operation.
pinMode(redPin, OUTPUT);
pinMode(grnPin, OUTPUT);
pinMode(bluPin, OUTPUT);
pinMode(sensor, INPUT);
if (analogRead(sensor) <= 200)
redtoyellow();
yellowtogreen();
greentocyan();
cyantoblue();
bluetomagenta();
magentatored();
else if (analogRead(sensor) >= 201)
digitalWrite(redPin, LOW);
digitalWrite(grnPin, LOW);
digitalWrite(bluPin, LOW);
void redtoyellow()
digitalWrite(redPin, HIGH);
// fade up green
for(byte i=1; i<100; i++) {
byte on = i;
byte off = 100-on;
for( byte a=0; a<100; a++ ) {
digitalWrite(grnPin, HIGH);
delayMicroseconds(on);
delayMicroseconds(off);
void yellowtogreen()
// fade down red
byte on = 100-i;
byte off = i;
void greentocyan()
// fade up blue
byte on = i;
byte off = 100-on;
digitalWrite(bluPin, HIGH);
void cyantoblue()
// fade down green
byte on = 100-i;
byte off = i;
void bluetomagenta()
// fade up red
byte on = i;
byte off = 100-on;
void magentatored()
// fade down blue
byte on = 100-i;
byte off = i;
This runs from 3V3 and an ATtiny 85 @ 1 MHz internal RC clock very nicely. It would require trivial modification to do as you describe... All the code.. is there, It just needs a little re-arranging.
