Replacing l293d with Pololu Dual VNH5019
Hey, guys, I am currently using an l293d in my robot to drive to 2dc motors but now for my project, I need to use 2 12v motors with higher power consumption so obviously l293d can’t handle more than 1A so if I were to replace the l293d with Pololu Dual VNH5019 would I need to change the code or can I use the same code as below and also as for the schematic of this new motor driver I am confused about what is the use of M1/M2PWM pin on the motor driver?
#include <IRremote.h>
   Left Motor
// IN 1
#define LM_IN1    2
// IN 2
#define LM_IN2    4
   Right Motor
// IN 3
#define RM_IN3    5
// IN 4
#define RM_IN4    7
// IR receiver
# define RECV_PIN 10
IRrecv irrecv(RECV_PIN);
decode_results results;
//HEX codes for buttons
#define FWD       0xFD8877 // go forward
#define LFT       0xFD28D7 // go left
#define RGT       0xFD6897 // go right
#define BWD       0xFD9867 // go backward
#define STOP      0xFD30CF // stop
#define RESET     0xFD00FF // Resets the Arduino Board(RED)
unsigned long int value=0;
 ************Arduino Reset Pin**************
#define RESET_PIN A0
  // set mode of the pins as output
  for (int i = 2; i <= 7; i++) {
    pinMode(i, OUTPUT);
  // start serial communication
  // In case the interrupt driver crashes on setup, give a clue
  // to the user what's going on.
  Serial.println("Enabling IRin");
  irrecv.enableIRIn(); // Start the receiver
  Serial.println("Enabled IRin");
  if (irrecv.decode(&results)) {
    value = results.value;
    Serial.println(value, HEX);
    irrecv.resume(); // Receive the next value
    delay(200);
  delay(100);
  check_Inst(value);
  value=0;
void check_Inst(long int value) {
  switch (value) {
    case FWD:
      go_Forward();
    case LFT:
      go_Left();
    case RGT:
      go_Right();
    case BWD:
      go_Backward();
    case STOP:
      go_Stop();
    case RESET:
      pinMode(RESET_PIN,OUTPUT);
      digitalWrite(RESET_PIN,HIGH);
    default:
      value = 0;
void go_Forward() {
  movement_Inst_Fwd();
  delay(10);
void go_Left() {
  movement_Inst_Lft();
  delay(10);
void go_Right() {
  movement_Inst_Rgt();
  delay(10);
void go_Backward(){
  movement_Inst_Bwd();
  delay(10);
void go_Stop(){
  movement_Inst_Stp();
  delay(10);
 * These movement instruction are repeated several times in the code
void movement_Inst_Fwd(void){
  Serial.println("Going_Forward");
  // forward movement instructions
  digitalWrite(LM_IN1,HIGH);
  digitalWrite(LM_IN2,LOW);
  digitalWrite(RM_IN3,HIGH);
  digitalWrite(RM_IN4,LOW);
void movement_Inst_Lft(void){
  Serial.println("Going_Left");
  // Left movement instructions
  digitalWrite(LM_IN1,LOW);
  digitalWrite(RM_IN3,LOW);
void movement_Inst_Rgt(void){
  Serial.println("Going_Right");
  // Rgt movement instructions
void movement_Inst_Bwd(void){
  Serial.println("Going_Backward");
  // Bwd movement instructions
  digitalWrite(LM_IN2,HIGH);
  digitalWrite(RM_IN4,HIGH);
void movement_Inst_Stp(void){
  Serial.println("Stopping");
  // Stp movement instructions
You will very likely need to alter the code that actually sets the driver outputs.
Please post links to data sheets for the motor as well as the drivers.
Motor stall current is very important to know.
12v motor
Pololu Dual VNH5019
like I don't have much knowledge about coding could you please explain what exactly I should be looking to change or just give me a good idea as to what I should be looking at?
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
If You provide the links being asked for an answer will be more precise.
I think about the functions go_Forward, go_Backward etc.
But I would like the data sheets before suggesting any details. All in order to awoid misleading You.
https://www.jaycar.com.au/12v-6-500-rpm-dc-electric-motor/p/YM2718
here are the 2 links as you asked the datasheet is also in those links!
