Replacing PulseIn() Function
Hi I have been using the pulseIn() function for a dust sensor I purchased. I have now purchased another one and realised you cant use the pulseIn() function twice in the same sketch.
I found out that I can use External Interrupts which I found on this site: Three Ways To Read A PWM Signal With Arduino | BenRipley.com
I have used there code example but changed it a bit because I want to measure from HIGH to LOW so the pulse in function to do this would be:
pulseIn(3, LOW);
so I wrote this code to replace that function:
volatile int pwm_value = 0;
volatile int prev_time = 0;
    attachInterrupt(0, falling, FALLING);
void rising() {
  pwm_value = micros()-prev_time;
  Serial.println(pwm_value);
void falling() {
  attachInterrupt(0, rising, RISING);
  prev_time = micros();
I just used the example from the link above. I never get anything printed to my Serial Monitor which is odd because I would have though even if it wasnt working I would see something.
I tried adding Serial.print("hello"); to the setup and that didnt print either so I am not sure if I have done something wrong.
The "hello" message is now printing I just added while(!Serial); so now it waits until it loads. The attachInterrupt still isnt printing anything so these issues werent related.
UPDATE
I have got it printing to the serial monitor. The fix was using digitalPinToInterrupt(3) like so attachInterrupt(digitalPinToInterrupt(3), falling, FALLING);
I then decided to run the pulseIn() function and the attachInterrupt function one after another and the results arent anywhere near each other. I know they wont be identical but they are way off.
Here is the new code that I have written:
int pin_large = 3;
    pinMode(pin_large,INPUT);
    long duration_large = pulseIn(pin_large, LOW);
    Serial.println(duration_large);
    Serial.println("");
    delay(6000);
void rising() {
void falling() {
  attachInterrupt(digitalPinToInterrupt(3), rising, RISING);
Does this look right? I am going to keep working on it so I will keep you updated.
The pwm_value variable sometimes prints minus numbers so there is clearly something wrong.
You might want to look up what micros() returns. Hint: It is NOT an int.
