replacing serial port instruction with actual sketch
hi, I have an adafruit sound board. I can tell it what to do through my arduino through the serial port. is it possible to write a sketch/program so I don't have to sit in front of my computer to have it play tracks in a specific order. I have looked everywhere but can not find a definitive answer. or would a SD card reader be a better choice?
thanks.
Fredric58:
is it possible to write a sketch/program so I don’t have to sit in front of my computer to have it play tracks in a specific order.
Yes. Triggering Audio | Adafruit Audio FX Sound Board | Adafruit Learning System
ok, making progress slowly. this will play 1 track that loops.
how do i make it play 1 track, delay 25 sec, play another track, delay 25 sec and have those 2 go around in a loop?
Thanks
Menu driven control of a sound board over UART.
Commands for playing by # or by name (full 11-char name)
Hard reset and List files (when not playing audio)
Vol + and - (only when not playing audio)
Pause, unpause, quit playing (when playing audio)
Current play time, and bytes remaining & total bytes (when playing audio)
Connect UG to ground to have the sound board boot into UART mode
uint8_t TRACK_15 = 15;
int PIN_ACT = 12;
int act_val = 0;
#include <SoftwareSerial.h>
#include “Adafruit_Soundboard.h”
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 7
#define SFX_RX 8
// Connect to the RST pin on the Sound Board
#define SFX_RST 4
// You can also monitor the ACT pin for when audio is playing!
// we’ll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
// pass the software serial to Adafruit_soundboard, the second
// argument is the debug port (not used really) and the third
// arg is the reset pin
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
// can also try hardware serial with
// Adafruit_Soundboard sfx = Adafruit_Soundboard(&Serial1, NULL, SFX_RST);
pinMode( PIN_ACT, INPUT_PULLUP );
Serial.println(“Adafruit Sound Board!”);
// softwareserial at 9600 baud
ss.begin(9600);
// can also do Serial1.begin(9600)
if (!sfx.reset()) {
Serial.println(“Not found”);
while (1);
Serial.println(“SFX board found”);
act_val = digitalRead(PIN_ACT);
if ( act_val == HIGH ) {
sfx.playTrack(TRACK_15);
the wav files are 5 seconds long if it matters.
