Reprogramming an Arduino Micro
I have an Arduino micro which I am trying to reprogram using the ISP header. I have remove R4 on the board which pulls the HWB pin to ground. (Not sure if this is necessary?)
I am using aan AVR JTAG ICE MkII.
I can read the micro identity correctly, I can read fuses, I can erase the device etc. However I can't reprogram it. When I try to load my COFF file into it I just get the message "Failed to identify target.."
I am an experienced AVR programmed with 128P etc but I've not used the 32U4. How do the fuses need to be set to achieve this?
Incidentally, I am powering the board via USB and the power light is on so all seems OK, I just can't reprogram.
Any help appreciated.
  • I am using an AVR JTAG ICE MkII.
  • I am powering the board via USB and the power light is on so all seems OK, I just can't reprogram.
I would try unplugging the 32u4 board from the USB... the MkII can power for reprogramming if board current is small.
Ray
