Hi All. I am repurposing some code written for a Nano Every, to use on a Nano I have available. The Nano is a Chinese clone. I have made a few changes to the code already, specifically changing the software serial ports for the DFPlayer to remove them from TX/RX on the Nano so I can try to debug the thing while connected to the computer. The OLED display code works fine. But the DFPlayer won't play anything, and the trigger buttons on D2 and D3 don't do anything either. D2 is the "fire" button and should change the 128x32 display, but does nothing. D3 also does nothing. So I'm a bit stuck as to what I have got wrong in the code here. Any advice greatly appreciated!
The Code:
// This script is a simple Blaster OS; By default is plays a blast sound and lights red; Pressing the mode change button
// switches to stun; In stun the stun sound plays and lights blue;
// Ammo count starts at 50 and counts down with bars; At zero empty click plays until mode change button is pressed for reload
// Sounds are read from SD card loaded in DFPLayer mini
// DFPlayer Mini library that seems to work with all of the DFPlayer Minis
#include <DFPlayerMini_Fast.h>
#include <Arduino.h>
#include <U8g2lib.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(4, 5); // RX, TX
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
//128x32 Ammo display on pins D9 & D10
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R3, /* clock=*/ 9, /* data=*/ 10, /* reset=*/ U8X8_PIN_NONE); // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
//64x32 Scop display on pins A4 & A5 (native Arduino Every SDA SCL pins)
U8G2_SSD1306_64X32_1F_1_HW_I2C u8g3(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
// End of constructor list
// pin definitions
//Fire button connects to pin D8
int fire = 2;
//Mode change button connects to pin D3
int modechange = 3;
//Addressable LED data pin D11
#define PIN 11 //LED Data Pin
#define NUM_LEDS 2 //Number of LEDs that will be lit
// global variables
//These are the intial values that the script uses to setup counts for mode changes and fire button presses
int count1 = 1;
int count2 = 1;
int lastButtonState1 = 1;
int lastButtonState2 = 1;
long unsigned int lastPress1;
long unsigned int lastPress2;
volatile int buttonFlag1;
volatile int buttonFlag2;
int debounceTime = 20;
int ammo = 50;
DFPlayerMini_Fast myMP3;
//Define addresable LED variables
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// setup pin modes
pinMode(modechange, INPUT_PULLUP);
pinMode(fire, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(fire), ISR_button1, CHANGE);
attachInterrupt(digitalPinToInterrupt(modechange), ISR_button2, CHANGE);
Serial.begin(9600); // dont forget to set your serial monitor speed to whatever is set here
Serial.println("Running");
strip.begin();
strip.show();
u8g2.begin();
u8g3.begin();
//DFPlayer Setup
mySerial.begin(9600);
myMP3.begin(mySerial, true);
Serial.println("Setting volume to max");
myMP3.volume(30); // Set volume 0 to 30 (max is 30)
// Ammo Count Boxes
u8g2.setDrawColor(1);
u8g2.setFontPosTop();
u8g2.setFontDirection(0);
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_inb19_mn);
u8g2.setCursor (2, 2);
u8g2.print(ammo);
//Draw Five Ammo Count Boxes
u8g2.drawBox(2,110,30,17);
u8g2.drawBox(2,91,30,17);
u8g2.drawBox(2,72,30,17);
u8g2.drawBox(2,53,30,17);
u8g2.drawBox(2,34,30,17);
u8g2.sendBuffer();
//Play initial startup sound
Serial.println("Play startup sound");
//Triggers the startup sound to play
//Format calls the directory on the SD card 01 and the third track; make sure files are named with 001, 002, 003, etc)
myMP3.play(3);
//Fire button check loop
u8g3.firstPage();
do {
int a = random(1, 12);
int b = random(1, 12);
int c = random(1, 12);
int d = random(1, 12);
int e = random(70, 90);
//Draw Scope
u8g3.drawCircle(32, 15, 15);//Outer Ring
u8g3.drawCircle(32, 15, 2);//Inner ring
u8g3.drawLine(20, 15, 15, 15);//left hash
u8g3.drawLine(44, 15, 49, 15);//right hash
u8g3.drawLine(32, 30, 32, 25);//bottom hash
u8g3.drawLine(32, 1, 32, 5);//top hash
u8g3.setFont(u8g2_font_tom_thumb_4x6_tf);
u8g3.setCursor (46, 6);
u8g3.print("TI-23");
u8g3.setCursor(52, 26);
u8g3.print("RNG");
u8g3.setCursor(52, 32);
u8g3.print(e);
u8g3.print("m");
//Top Left Bars
u8g3.drawLine(1, 1, a, 1);//bar 1
u8g3.drawLine(1, 3, b, 3);//bar 2
u8g3.drawLine(1, 5, c, 5);//bar 3
u8g3.drawLine(1, 7, d, 7);//bar 4
delay(50);
} while ( u8g3.nextPage() );
//Debug statements commented out
//Serial.print("LastButton:");
//Serial.println(lastButtonState1);
if((millis() - lastPress1) > debounceTime && buttonFlag1)
lastPress1 = millis(); //update lastPress
if(digitalRead(fire) == 0 && lastButtonState1 == 1) //if button is pressed and was released last change
Serial.println("Fire:");
count1 = count1 + 1;
//Serial.println(count1);
//Blast - subroutine to play blast sound and light
if (count2 == 1 && ammo != 0){
colorWipe(0xff,0x00,0x00, 2);
colorWipe(0x00,0x00,0x00, 2);
myMP3.play(1);
//Stun - Subroutine if in stun mode
if (count2 == 2 & ammo != 0){
colorWipe(0x00,0x00,0xff, 2);
myMP3.play(2);
//Empty - Subroutine if empty; Plays empty sound until mode button is pressed for reload
if (ammo == 0){
Serial.println("Empty");
myMP3.play(5);
//Ammo Bar
//Five bars - Displays five bars on ammo display based on ammo count above 40
if ((ammo <=50) && (ammo >= 40))
ammo = ammo - 1;
//Five ammo count boxes already drawn
Serial.println("50-40");
u8g2.print(ammo);
u8g2.sendBuffer();
//four bars -Displays four bars on ammo display based on ammo count above 30
if ((ammo <= 39) && (ammo >= 30))
ammo = ammo - 1;
//Draw Four Ammo Count Boxes
Serial.println("39-30");
u8g2.clearBuffer();
Serial.println(ammo);
u8g2.print(ammo);
u8g2.sendBuffer();
//Three bars Displays three bars on ammo display based on ammo count above 20
if ((ammo <= 29) && (ammo >= 20)) {
ammo = ammo - 1;
Serial.println("29-20");
u8g2.clearBuffer();
u8g2.print(ammo);
u8g2.sendBuffer();
//Two bars Displays on bar on ammo display based on ammo count above 10
if ((ammo <= 19) && (ammo >= 10)) {
ammo = ammo - 1;
Serial.println("19-10");
u8g2.clearBuffer();
u8g2.print(ammo);
u8g2.sendBuffer();
//One bars
if ((ammo <= 9) && (ammo >= 1)) {
ammo = ammo - 1;
u8g2.clearBuffer();
u8g2.print(ammo);
u8g2.sendBuffer();
//Zero bars
if ((ammo == 0)) {
u8g2.clearBuffer();
u8g2.print(ammo);
u8g2.sendBuffer();
//lastButtonState1 = 0; //record the lastButtonState
else if(digitalRead(fire) == 1 && lastButtonState1 == 0) //if button is not pressed, and was pressed last change
lastButtonState1 = 1; //record the lastButtonState
buttonFlag1 = 0;
//Modechange check loop - checks if mode change button has been pressed
if((millis() - lastPress2) > debounceTime && buttonFlag2)
lastPress2 = millis(); //update lastPress
if(digitalRead(modechange) == 0 && lastButtonState2 == 1) //if button is pressed and was released last change
Serial.println("Mode:");
//Count2 is used to determin mode 1=kill, 2=stun
count2 = count2 + 1;
Serial.println("Count Increase");
if (count2 == 3) {
count2 = 1;
//Play sound for mode change
if (ammo != 0) {
myMP3.play(4);
//Reload Sequence
if (ammo == 0) {
Serial.println("Reload");
myMP3.play(3);
ammo = 50;
//Re-Draw Five Ammo Count Boxes for reload
u8g2.print(ammo);
u8g2.sendBuffer();
//Decreases count2 by 1 to prevent mode change on reload
count2= count2 - 1;
//Serial.println(count2);
//lastButtonState2 = 0; //record the lastButtonState
else if(digitalRead(modechange) == 1 && lastButtonState2 == 0) //if button is not pressed, and was pressed last change
lastButtonState2 = 1; //record the lastButtonState
buttonFlag2 = 0;
void ISR_button1()
buttonFlag1 = 1;
void ISR_button2()
buttonFlag2 = 1;
float SpeedDelay = 0.1;
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
for(uint16_t i=0; i<NUM_LEDS; i++) {
setPixel(i, red, green, blue);
showStrip();
delay(SpeedDelay);
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
