request for help !!
In this case you need accelerometers. You have to think about the range they have to measure. The common sensors go up to about 10g, but for your application you might need much higher limits to actually have a differentiation between bumps. The other type of sensor that may be of use for you is a shock sensor. But there you probably have to have different types because the usually only give you a digital signal and not a floating value.
