I am trying to connect my ESP8266 to internet server through Arduino Mega and it is throwing this error
code:-
boolean setup_ESP(){//returns a '1' if successful
ESP8266.print("AT\r\n");// Send just 'AT' to make sure the ESP is responding
//this read_until_... function is used to find a keyword in the ESP response - more on this later and in the function itself
if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0))//go look for keyword "OK" with a 5sec timeout
Serial.println("ESP CHECK OK");
Serial.println("ESP CHECK FAILED");
serial_dump_ESP();//this just reads everything in the buffer and what's still coming from the ESP
ESP8266.print("AT+RST\r\n");// Give it a reset - who knows what condition it was in, better to start fresh
if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0))//go look for keyword "Ready" - takes a few seconds longer to complete
Serial.println("ESP RESET OK");//depneding on the FW version on the ESP, sometimes the Ready is with a lowercase r - ready
Serial.println("ESP RESET FAILED");
serial_dump_ESP();
ESP8266.print("AT+CWMODE=");// set the CWMODE
ESP8266.print(CWMODE);//just send what is set in the constant
ESP8266.print("\r\n");
Serial.println("ESP CWMODE SET");
Serial.println("ESP CWMODE SET FAILED"); //probably going to fail, since a 'no change' is returned if already set - would be nice to check for two words
serial_dump_ESP();
//Here's where the SSID and PW are set
ESP8266.print("AT+CWJAP=\"");// set the SSID AT+CWJAP="SSID","PW"
ESP8266.print(SSID_ESP);//from constant
ESP8266.print("\",\"");
ESP8266.print(SSID_KEY);//form constant
ESP8266.print("\"\r\n");
if(read_until_ESP(keyword_OK,sizeof(keyword_OK),10000,0))//go look for keyword "OK"
Serial.println("ESP SSID SET OK");
Serial.println("ESP SSID SET FAILED");
serial_dump_ESP();
//This checks for and stores the IP address
Serial.println("CHECKING FOR AN IP ADDRESS");
ESP8266.print("AT+CIFSR\r\n");//command to retrieve IP address from ESP
if(read_until_ESP(keyword_rn,sizeof(keyword_rn),10000,0)){//look for first \r\n after AT+CIFSR echo - note mode is '0', the ip address is right after this
if(read_until_ESP(keyword_rn,sizeof(keyword_rn),1000,1)){//look for second \r\n, and store everything it receives, mode='1'
//store the ip adress in its variable, ip_address[]
for(int i=1; i<=(scratch_data_from_ESP[0]-sizeof(keyword_rn)+1); i++)//that i<=... is going to take some explaining, see next lines
ip_address[i] = scratch_data_from_ESP[i];//fill up ip_address with the scratch data received
//i=1 because i=0 is the length of the data found between the two keywords, BUT this includes the length of the second keyword, so i<= to the length minus
//size of teh keyword, but remember, sizeof() will return one extra, which is going to be subtracted, so I just added it back in +1
ip_address[0] = (scratch_data_from_ESP[0]-sizeof(keyword_rn)+1);//store the length of ip_address in [0], same thing as before
Serial.print("IP ADDRESS = ");//print it off to verify
for(int i=1; i<=ip_address[0]; i++)//send out the ip address
Serial.print(ip_address[i]);
Serial.println("");
}}//if first \r\n
Serial.print("IP ADDRESS FAIL");
serial_dump_ESP();
ESP8266.print("AT+CIPMUX=");// set the CIPMUX
ESP8266.print(CIPMUX);//from constant
if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0))//go look for keyword "OK" or "no change
Serial.println("ESP CIPMUX SET");
Serial.println("ESP CIPMUX SET FAILED");
serial_dump_ESP();
//that's it! Could be done by nesting everything together, so if one thing fails, it returns '0', and if it gets all the way through it returns '1'...oh well
}//setup ESP
This is the compiler's error:
Error:-
Arduino: 1.8.14 Hourly Build 2021/04/08 03:25 (Linux), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
WARNING: library LiquidCrystal_I2C claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
<command-line>: error: expected unqualified-id before numeric constant
/home/udit/Desktop/HomeAutomationSystem/ESP_tutorial/MAIN_ESP8266/MAIN_ESP8266.ino:148:16: note: in expansion of macro 'ESP8266'
148 | SoftwareSerial ESP8266(ESP8266_RX, ESP8266_TX);// rx tx
/home/udit/Desktop/HomeAutomationSystem/ESP_tutorial/MAIN_ESP8266/connect_ESP.ino: In function 'boolean connect_ESP()':
connect_ESP:7:11: error: request for member 'print' in '1', which is of non-class type 'int'
7 | ESP8266.print("AT+CIPSTART=0,\"TCP\",\"www.homiecube.000webhostapp.com\",80\r\n");//connect to your web server
connect_ESP:14:11: error: request for member 'print' in '1', which is of non-class type 'int'
14 | ESP8266.print("AT+CIPSEND=0,");//send AT+CIPSEND=0, size of payload
connect_ESP:15:11: error: request for member 'print' in '1', which is of non-class type 'int'
15 | ESP8266.print(payload_size);//the payload size
connect_ESP:17:11: error: request for member 'print' in '1', which is of non-class type 'int'
17 | ESP8266.print("\r\n\r\n");//cap off that command with a carriage return and new line feed
connect_ESP:26:13: error: request for member 'print' in '1', which is of non-class type 'int'
26 | ESP8266.print(payload[i]);
/home/udit/Desktop/HomeAutomationSystem/ESP_tutorial/MAIN_ESP8266/read_until_ESP.ino: In function 'boolean read_until_ESP(const char*, int, int, byte)':
read_until_ESP:18:28: error: request for member 'available' in '1', which is of non-class type 'int'
18 | while(!ESP8266.available()){//wait until a new byte is sent down from the ESP - good way to keep in lock-step with the serial port
read_until_ESP:25:24: error: request for member 'read' in '1', which is of non-class type 'int'
25 | data_in[i]=ESP8266.read();// save the byte to the buffer 'data_in[]
read_until_ESP:56:28: error: request for member 'available' in '1', which is of non-class type 'int'
56 | while(!ESP8266.available()){// same thing as done in the buffer
read_until_ESP:65:33: error: request for member 'read' in '1', which is of non-class type 'int'
65 | data_in[key_size-1]=ESP8266.read();//save the new data in the last position in the buffer
/home/udit/Desktop/HomeAutomationSystem/ESP_tutorial/MAIN_ESP8266/serial_dump_ESP.ino: In function 'void serial_dump_ESP()':
serial_dump_ESP:5:17: error: request for member 'available' in '1', which is of non-class type 'int'
5 | while(ESP8266.available()){
serial_dump_ESP:6:19: error: request for member 'read' in '1', which is of non-class type 'int'
6 | temp =ESP8266.read();
/home/udit/Desktop/HomeAutomationSystem/ESP_tutorial/MAIN_ESP8266/setup_ESP.ino: In function 'boolean setup_ESP()':
setup_ESP:3:11: error: request for member 'print' in '1', which is of non-class type 'int'
3 | ESP8266.print("AT\r\n");// Send just 'AT' to make sure the ESP is responding
setup_ESP:11:12: error: request for member 'print' in '1', which is of non-class type 'int'
11 | ESP8266.print("AT+RST\r\n");// Give it a reset - who knows what condition it was in, better to start fresh
setup_ESP:19:12: error: request for member 'print' in '1', which is of non-class type 'int'
19 | ESP8266.print("AT+CWMODE=");// set the CWMODE
setup_ESP:20:12: error: request for member 'print' in '1', which is of non-class type 'int'
20 | ESP8266.print(CWMODE);//just send what is set in the constant
setup_ESP:21:12: error: request for member 'print' in '1', which is of non-class type 'int'
21 | ESP8266.print("\r\n");
setup_ESP:29:12: error: request for member 'print' in '1', which is of non-class type 'int'
29 | ESP8266.print("AT+CWJAP=\"");// set the SSID AT+CWJAP="SSID","PW"
setup_ESP:30:12: error: request for member 'print' in '1', which is of non-class type 'int'
30 | ESP8266.print(SSID_ESP);//from constant
setup_ESP:31:12: error: request for member 'print' in '1', which is of non-class type 'int'
31 | ESP8266.print("\",\"");
setup_ESP:32:12: error: request for member 'print' in '1', which is of non-class type 'int'
32 | ESP8266.print(SSID_KEY);//form constant
setup_ESP:33:12: error: request for member 'print' in '1', which is of non-class type 'int'
33 | ESP8266.print("\"\r\n");
setup_ESP:42:11: error: request for member 'print' in '1', which is of non-class type 'int'
42 | ESP8266.print("AT+CIFSR\r\n");//command to retrieve IP address from ESP
setup_ESP:61:12: error: request for member 'print' in '1', which is of non-class type 'int'
61 | ESP8266.print("AT+CIPMUX=");// set the CIPMUX
setup_ESP:62:12: error: request for member 'print' in '1', which is of non-class type 'int'
62 | ESP8266.print(CIPMUX);//from constant
exit status 1
option enabled in File -> Preferences.
