As mentioned earlier, you should post your code in a post, not as an attachment
Test_Tacho_control.ino
Dit programma is voor megatronica.
Het is geschreven om 2 motoren te sturen.
H. M. Sietsema
// library voor 2,8" TFT scherm
#include <Adafruit_TFTLCD.h>
// #include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
// library voor drukknoppen
#include <ezButton.h>
// generike library
#include <Wire.h>
#include <SPI.h>
//3.5 TFT scherm
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
// #define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
//kleuren definieren
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
//omreken factoren die makkelijk kunnen zijn
#define PI 3.1415926535897932384626433832795
#define HALF_PI 1.5707963267948966192313216916398
#define TWO_PI 6.283185307179586476925286766559
#define DEG_TO_RAD 0.017453292519943295769236907684886
#define RAD_TO_DEG 57.295779513082320876798154814105
//bepalen pinnen voor motorsturing
#define Motor1Pin1 0
#define Motor1Pin2 1
#define Motor2Pin1 12
#define Motor2Pin2 13
#define Motor1Speed 10
#define Motor2Speed 11
float aHall_sensor_tijd_1[10];
float aHall_sensor_tijd_2[10];
float aHall_sensor_tijd_3[10];
float aHall_sensor_tijd_4[10];
float average_hall_1, average_hall_2, average_hall_3, average_hall_4;
int count_hall_1 = 0, count_hall_2 = 0, count_hall_3 = 0, count_hall_4 = 0, Hall_direction_tijd_1, Hall_direction_tijd_2;
int delay_Display = 0;
int delay_average = 0;
int newPosition, oldPosition, constPosition, gasPosition;
int Draairichting_1_gemeten, Draairichting_2_gemeten, RPM1, RPM2;
int Button1Status, Button2Status;
int Button1Var = 1;
int Button1Toggle = 1;
int pid_speed = 0;
float kp = 2.25;
float ki = 0.01;
float kd = 0.005;
int error = 0;
float PIDPosition = 0; //PID berekende gaspositie
int diff = 0;
ezButton button1(22); //wijs pin 22 aan drukknop 1 toe
ezButton button2(24); //wijs pin 24 aan drukknop 2 toe
char ButtonDisplayValue1[26];
char ButtonDisplayValue2[26];
char *Draairichting1;
char *Draairichting2;
int Potmeter1 = A5;
int PotValue = 0;
char PotDisplayValue[24];
char gasDisplayValue[24];
char PIDDisplayValue[24];
char TimeDisplayValue1[24];
char TimeDisplayValue2[24];
char Gemetenrichting1[26];
char Gemetenrichting2[26];
char TimeSpeedSensor1[24];
char TimeSpeedSensor2[24];
Serial3.begin(9600);
// Zet de pinnen voor het correcte gebruik
pinMode(Motor1Pin1, OUTPUT);
pinMode(Motor1Pin2, OUTPUT);
pinMode(Motor2Pin1, OUTPUT);
pinMode(Motor2Pin2, OUTPUT);
pinMode(Motor1Speed, OUTPUT);
pinMode(Motor2Speed, OUTPUT);
// initialisatie van het TFT display
tft.begin(0x9486);
tft.setRotation(0);
tft.setTextSize(2);
tft.setTextColor(WHITE, BLACK);
// iSetAchtergrondTFT(); //Subroutine voor het schrijven van de achtergrond van het TFT scherm
tft.fillScreen(BLACK); //set de achtergrond zwart
tft.drawRect(0, 0, 320, 480, WHITE);
Serial.available() < 4;
Draairichting_1_gemeten = Serial3.parseInt();
Draairichting_2_gemeten = Serial3.parseInt();
RPM1 = Serial3.parseInt();
RPM2 = Serial3.parseInt();
Serial.println(Draairichting_1_gemeten);
Serial.println(Draairichting_2_gemeten);
Serial.println(RPM1);
Serial.println(RPM2);
iUitleesPotmeter();
iButUitlezen();
iMotorControl();
// iPID();
if (delay_Display == 9) {
iDisplay();
delay_Display = 0;
else {
if (delay_Display < 9) {
delay_Display ++;
/* if(Hall_direction_tijd_1 < 20){
Draairichting_1_gemeten = "Rechts";
else{
Draairichting_1_gemeten = "Links ";
if(Hall_direction_tijd_2 < 20){
Draairichting_2_gemeten = "Rechts";
else{
Draairichting_2_gemeten = "Links ";
// RPM1 = (1/ (Hall_sensor_tijd_1 / 500000));
// RPM2 = (1/ (Hall_sensor_tijd_3 / 500000));
//////////// Functions ////////////
void iPID(void) {
error = Draairichting_1_gemeten - Draairichting_2_gemeten;
diff += error;
pid_speed = kp * error; + ki*diff;
pid_speed = (int)pid_speed;
if (pid_speed > 0) {
if (pid_speed < 255)
PIDPosition = 255;
PIDPosition = pid_speed;
if (pid_speed < 0) {
if (pid_speed < -255)
PIDPosition = 0;
pid_speed = abs(pid_speed);
PIDPosition = 255 - pid_speed;
void iUitleesPotmeter(void) {
PotValue = analogRead(Potmeter1);
Serial.println(PotValue);
gasPosition = 0;
gasPosition = map (PotValue, 0, 1023, 0, 255);
void iButUitlezen(void) {
button1.loop(); // MUST call the loop() function first
Button1Status = button1.getState();
if (Button1Status == 0 && Button1Var == 1) {
if (Button1Toggle == 0) {
Button1Toggle = 1;
else {
Button1Toggle = 0;
Button1Var = Button1Status;
void iAverage(void) {
int i = 0, j = 0;
average_hall_1 = 0;
average_hall_2 = 0;
while (i < 10) {
aHall_sensor_tijd_1[i] += average_hall_1;
i++;
average_hall_1 / 10;
while (j < 10) {
aHall_sensor_tijd_2[j] += average_hall_2;
j++;
average_hall_2 / 10;
delay_average = 0;
void iMotorControl(void) {
//Controlling speed (0 = off and 255 = max speed):
analogWrite(Motor1Speed, gasPosition); //ENA pin
analogWrite(Motor2Speed, gasPosition); //ENB pin
//Controlling spin direction of motors:
if (Button1Toggle == 1) {
digitalWrite(Motor1Pin1, HIGH);
digitalWrite(Motor1Pin2, LOW);
else {
digitalWrite(Motor1Pin1, LOW);
digitalWrite(Motor1Pin2, HIGH);
if (Draairichting_1_gemeten == "Rechts") {
digitalWrite(Motor2Pin1, HIGH);
digitalWrite(Motor2Pin2, LOW);
else {
digitalWrite(Motor2Pin1, LOW);
digitalWrite(Motor2Pin2, HIGH);
//////////// Visualisatie ////////////
void iDisplay(void) {
tft.setCursor(10, 10);
snprintf(PotDisplayValue, 24, "Potmeter waarde = %4i", PotValue);
tft.print(PotDisplayValue);
tft.setCursor(10, 30);
Draairichting1 = "Rechts";
else {
Draairichting1 = "Links ";
snprintf(ButtonDisplayValue1, 26, "Draairichting M1 = %s\n", Draairichting1);
tft.print(ButtonDisplayValue1);
tft.setCursor(10, 50);
Draairichting2 = "Rechts";
else {
Draairichting2 = "Links ";
snprintf(ButtonDisplayValue2, 26, "Draairichting M2 = %s\n", Draairichting2);
tft.print(ButtonDisplayValue2);
tft.setCursor(10, 80);
snprintf(gasDisplayValue, 24, "Motor M1 waarde = %4i", gasPosition);
tft.print(gasDisplayValue);
tft.setCursor(10, 100);
snprintf(PIDDisplayValue, 24, "Motor M2 waarde = %4i", PIDPosition);
tft.print(PIDDisplayValue);
tft.setCursor(10, 120);
snprintf(TimeDisplayValue1, 24, "Toerental M1 = %4i", RPM1);
tft.print(TimeDisplayValue1);
tft.setCursor(10, 140);
snprintf(TimeDisplayValue2, 24, "Toerental M2 = %4i", RPM2);
tft.print(TimeDisplayValue2);
tft.setCursor(10, 160);
snprintf(Gemetenrichting1, 26, "Draairichting M1 = %s\n", Draairichting_1_gemeten);
tft.print(Gemetenrichting1);
tft.setCursor(10, 180);
snprintf(Gemetenrichting2, 26, "Draairichting M2 = %s\n", Draairichting_2_gemeten);
tft.print(Gemetenrichting2);
tft.setCursor(10, 300);
snprintf(TimeSpeedSensor1, 24, "M1 tijd sensor = %6i", Hall_direction_tijd_1);
tft.print(TimeSpeedSensor1);
tft.setCursor(10, 320);
snprintf(TimeSpeedSensor2, 24, "M2 tijd sensor = %6i", Hall_direction_tijd_2);
tft.print(TimeSpeedSensor2);
Test_Tacho_speed.ino
H. M. Sietsema
// generike library
#include <Wire.h>
#include <SPI.h>
//ingangen voor de snelheidssensoren.
#define MotorHall1 18
#define MotorHall2 19
#define MotorHall3 20
#define MotorHall4 21
byte last_channel_1, last_channel_2, last_channel_3, last_channel_4;
double Hall_sensor_tijd_1, Hall_sensor_tijd_2, Hall_sensor_tijd_3, Hall_sensor_tijd_4;
unsigned long timer_1, timer_2, timer_3, timer_4;
int Hall_direction_tijd_1, Hall_direction_tijd_2;
int RPM1, RPM2;
int Draairichting_1_gemeten, Draairichting_2_gemeten;
Serial3.flush();
//interupt setup
attachInterrupt(digitalPinToInterrupt(18), HallPuls1, RISING);
attachInterrupt(digitalPinToInterrupt(19), HallPuls2, RISING);
attachInterrupt(digitalPinToInterrupt(20), HallPuls3, RISING);
attachInterrupt(digitalPinToInterrupt(21), HallPuls4, RISING);
if (Hall_direction_tijd_1 < 20) {
Draairichting_1_gemeten = 1;
else {
Draairichting_1_gemeten = 0;
Serial3.write(Draairichting_1_gemeten);
//Serial3.write(Draairichting_1_gemeten%256);
if (Hall_direction_tijd_2 < 20) {
Draairichting_2_gemeten = 1;
else {
Draairichting_2_gemeten = 0;
Serial3.write(Draairichting_2_gemeten);
//Serial3.write(Draairichting_2_gemeten%256);
RPM1 = (1 / (Hall_sensor_tijd_1 / 500000));
RPM2 = (1 / (Hall_sensor_tijd_3 / 500000));
Serial3.write(RPM1);
Serial3.write(RPM2);
void HallPuls1(void) { // this function will run if a pin change is detected on portB
//Tacho 1=====================================================
if (last_channel_1 == 0) { // Input 8 changed from 0 to 1
last_channel_1 = 1; // Remember current state
timer_1 = micros(); // Set timer_1 to micros()
else if (last_channel_1 == 1) { // Input 8 changed from 1 to 0
last_channel_1 = 0; // Remember current state
Hall_sensor_tijd_1 = micros() - timer_1; // Calculate total micros()
void HallPuls2(void) {
if (RPM1 < 25) {
Hall_direction_tijd_1 = micros() - timer_1;
void HallPuls3(void) {
//Tacho 2=====================================================
if (last_channel_3 == 0) { // Input 8 changed from 0 to 1
last_channel_3 = 1; // Remember current state
timer_3 = micros(); // Set timer_1 to micros()
else if (last_channel_3 == 1) { // Input 8 changed from 1 to 0
last_channel_3 = 0; // Remember current state
Hall_sensor_tijd_3 = micros() - timer_3; // Calculate total micros()
void HallPuls4(void) {
if (RPM2 < 25) {
Hall_direction_tijd_2 = micros() - timer_2;
