Request web pages in loop
I need to make a request of the content of a web page in loop and dynamic parameters.
Like this:
  enviaDadosLuz();
  delay(tempodelay);
void enviaDadosLuz() {
  for (i = 0; i <= 15; i++) {
    client.stop();
    if (client.connect(server_ip, 8082)) {
      Serial.println("connecting...");
      Serial.println("connected");
      client.print("GET /luz.php?porta=");
      Serial.print("GET /luz.php?porta=");
      client.println(i);
      Serial.println(i);
      char c = client.read();
      client.println("Connection: close");
      Serial.println("Connection: close");
      client.println();
      //char c = client.read();
      Serial.println(c);
      Serial.println("connection failed");
I do not succeed in getting the contents of the web page.
Basic client test code.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
#include <Ethernet.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // myIP server test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    client.println("GET / HTTP/1.1"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    readString += c; //places captured byte in readString
  //Serial.println();
  client.stop(); //stop client
  Serial.println("client disconnected.");
  Serial.println("Data from server captured in readString:");
  Serial.print(readString); //prints readString to serial monitor
  Serial.println("End of readString");
  Serial.println("==================");
  readString=""; //clear readString variable
You do not determine that the server returned anything. You do not read all the data that the client object gets. You read ONE character, which you read before completing the request.
Look at the client example. It DOES work.
