Hello! Thank you for taking a look at this post. I could use the assistance of experienced Arduino programmers to resolve a complicated (for me) issue.
I have a button box that I'm trying to power from an Arduino Mega clone: The Elegoo Mega2560 R3.
I'm using the MegaJoy Library to convert the Arduino into an HID joystick. This part works perfectly, and for a limited subset of the buttons everything does what it's supposed to do. However, to fit all my inputs I put a bunch of the buttons into a diode matrix:
The matrix ALSO works as expected. If I set the Arduino into Arduino mode and output the matrix to Serial, all the keypresses are successfully reported. I'm using the Adafruit Keypad Library to read the keypresses.
However, this is where I get into trouble. I'm trying to translate the keypresses from the Adafruit Keypad Library into inputs that the Megajoy Library will understand as button presses for the HID joystick. The code compiles without any errors, but button presses aren't getting picked up from keys in the matrix.
Here's my code thus far. Obviously I am NOT a programmer and I'm just pulling bits and pieces from across the web, so I must be missing something fundamental in how I'm trying to move the Adafruit output into Megajoy. I think where this is failing is in the string I set up to compare against the output from Adafruit? I could use some assistance figuring out what I've missed or mangled.
Many thanks!
// Configuration file for use with AlanChatham's UnoJoy project: https://github.com/AlanChatham/UnoJoy
#include <Adafruit_Keypad.h>
#include <Adafruit_Keypad_Ringbuffer.h>
// Megajoy.h includes the UnoJoy library with customizations for use with an Arduino Mega. Theoretically we shouldn't need to make any changes to megajoy.h.
#include "MegaJoy.h"
int kbpress = 0;
// Now let's define the button matrix using Arduino's keypad.h library.
// My matrix has a bunch of empty nodes (not perfectly efficient, I know).
// These are represented by a space, which basically becomes a junk data warning.
// If space is expressed anywehre, then something has gone wrong.
const byte ROWS = 12; //rows
const byte COLS = 6; //columns
char keys[ROWS][COLS] = {
{'&', '1', '3', '5', '7', '&'},
{'&', '2', '4', '6', '8', '&'},
{'a', 'b', 'c', 'd', 'e', 'f'},
{'&', '&', 'g', '&', 'k', '&'},
{' ', ' ', 'h', ' ', 'l', ' '},
{' ', ' ', 'i', ' ', 'm', ' '},
{' ', ' ', 'j', ' ', 'n', ' '},
{'o', ' ', ' ', ' ', ' ', ' '},
{'p', 's', ' ', 'w', ' ', 'z'},
{' ', 't', 'v', 'x', ' ', '+'},
{'q', 'u', '9', 'y', ' ', '-'},
{'r', ' ', '0', ' ', ' ', ' '}
// These are the pins used for the columns and rows. This is where you're plugging in the actual wiring of your key matrix.
byte rowPins[ROWS] = {53, 52, 51, 50, 49, 48, 47, 46, 45, 44, 43, 42};
byte colPins[COLS] = {41, 40, 39, 38, 37, 36};
// This defines the customKeypad variable using the datatype Adafruit_Keypad
Adafruit_Keypad customKeypad = Adafruit_Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
// The serial connection is useful for testing the output of your key matrix, but it will interfere with MegaJoy. Uncomment this when testing the key matrix, then comment it out for the actual Megajoy configuration.
// Serial.begin(9600);
setupPins();
setupMegaJoy();
customKeypad.begin();
void setupPins(void) {
// Defining pins here will determine what pins are used as "normal" buttons. These buttons and switches will activate when shorted to ground.
// You can define any pins (except the serial pins) here by adding them to the function. You can create separate blocks by copying the existing section and defining a new range if you need to skip around other pins.
// Mine handles all pins between 22 and 30 as normal switches that aren't part of a key matrix.
for (int i = 22; i <= 30; i++) {
pinMode(i, INPUT);
digitalWrite(i, HIGH);
// This loop runs constantly. Effectively this polls all your buttons for new information about their status. We shouldn't need to make any changes here.
//char key = kpd.getKey();
//if (key != NO_KEY){
// Serial.println(key);}
// customKeypad.tick();
// while(customKeypad.available()){
// keypadEvent e = customKeypad.read();
// This line will cause the matrix keypad to output to the Serial connection. This is great for testing, but interferes with Megajoy.
// Uncomment this line to see what your key matrix is actually putting out. Comment it before working on the Megajoy portion of the code.
// Serial.print((char)e.bit.KEY);
// if(e.bit.EVENT == KEY_JUST_PRESSED) Serial.println(" pressed");
// else if(e.bit.EVENT == KEY_JUST_RELEASED) Serial.println(" released");
// delay(10);
// Since I'm documenting this for others, I figure I should add a little in here about Functions in C.
// This next line defines a variable. It does this in 3 parts. The first part is the variable's type. Normally this would be something like Byte or Char.
// In this case it's megaJoyControllerData_t. This type is defined in the Megajoy library.
// The second part is the variable (controllerData).
// The third part is where controllerData gets it's contents from. getControllerData is a function (defined below).
megaJoyControllerData_t controllerData = getControllerData();
setControllerData(controllerData);
// Here's the primary function for running MegaJoy. Any data that MegaJoy needs to interpret as a button press should be included in here somewhere.
// This function (called in the main loop) will determine which joystick buttons have been pressed.
// This is a function declaration, so the first part is the type of data the function is expected to return (megaJoyControllerData_t)
// The second part is the function's name (getControllerData)
// The third part is what variables are we passing in to the function. This is presently Void, meaning the function isn't waiting for data from elsewhere in the program.
megaJoyControllerData_t getControllerData(void) {
// Start by blanking out the variables so it's not full of junk data.
megaJoyControllerData_t controllerData = getBlankDataForMegaController();
// Scan the keyboard matrix
// If the keypad is available, then read the current key from it
while (customKeypad.available()) {
// We need a string we can walk through looking for matching keyboard events.
String keyring = "1234567890abcdefghijklmnopqrstuvwxyz+-";
// Did a key just get pressed? Walk the keyring string looking for a match
if (e.bit.EVENT == KEY_JUST_PRESSED) {
for (unsigned int j = 0; j < keyring.length(); j++) {
// I might be getting this wrong, but I think this should compare the current spot in the keyring string against the currently pressed key because I'm using an unsigned int.
if (keyring[j] == (char)e.bit.KEY) {
// This handles some funky math to skip over the keys reserved for non-matrix use by the normal Megajoy commands.
// This causes the matrix to fill in Joystick buttons starting from button 1, skipping any outside the matrix, and ending at the end of the matrix's range of possible buttons.
if (j <= 20) {
kbpress = j + 1;
kbpress = j + 11;
controllerData.buttonArray[(kbpress - 2) / 8] |= 1 << ((kbpress - 2) % 8);
else if (e.bit.EVENT == KEY_JUST_RELEASED) {
if (j <= 20) {
kbpress = j + 1;
kbpress = j + 11;
controllerData.buttonArray[(kbpress - 2) / 8] &= 0 << ((kbpress - 2) % 8);
// Small delay to prevent key bouncing.
delay(10);
// This is the old version of the string code for use with a different keypad library. Preserved here in case I need to go back to it.
//String keyring = "1234567890abcdefghijklmnopqrstuvwxyz+-";
//for (int j = 0; j < keyring.length(); j++) {
// if (j <= 20) {
// kbpress = j + 1;
// } else {
// kbpress = j + 11;
// if (customKeypad.isPressed(keyring[j])) {
// controllerData.buttonArray[(kbpress - 2) / 8] |= 1 << ((kbpress - 2) % 8);
// } else {
// controllerData.buttonArray[(kbpress - 2) / 8] &= 0 << ((kbpress - 2) % 8);
// This section should match what you've set in the setupPins function (Make sure to add 1 to the upper range, since this is less than, rather than less than or equal.
// This handles your "normal" buttons and switches that aren't part of a matrix. These pins, when shorted to ground, will report back a button press of the equivalant button (ex. pin 27 gets you button 27).
for (int i = 22; i < 31; i++) {
bool isPressed = !digitalRead(i);
// This next line is in here to reverse the output of keys 25 through 29. I'm using 3-pin illuminated automotive keys. These report back the reverse of a typical key (because closing the circuit sends 5V).
// You can modify this line to deal with any keys you want to reverse, or comment it out if you don't have any.
if (i > 24 && i < 29) {
isPressed = !isPressed;
// This line here converts your digital pin (from setupPins) into a button press
controllerData.buttonArray[(i - 2) / 8] |= (isPressed) << ((i - 2) % 8);
// Set the analog inputs
// Since analogRead(pin) returns a 10 bit value, we need to perform a bit shift operation to lose the 2 least significant bits and get an 8 bit number that we can use
// I've commented out most axes because my button box only has one analog dial. This isn't strictly necessary, but I figure it's best not to leave a bunch of random Analog Read actions in the middle of my setup if I'm not really using any.
// Which analog pin you use will determine which axis gets reported back to windows for your joystick. The first two are your standard joystick X and Y values.
// controllerData.analogAxisArray[0] = analogRead(A0);
// controllerData.analogAxisArray[1] = analogRead(A1);
controllerData.analogAxisArray[2] = analogRead(A2);
// controllerData.analogAxisArray[3] = analogRead(A3);
// controllerData.analogAxisArray[4] = analogRead(A4);
// controllerData.analogAxisArray[5] = analogRead(A5);
// controllerData.analogAxisArray[6] = analogRead(A6);
// controllerData.analogAxisArray[7] = analogRead(A7);
// controllerData.analogAxisArray[8] = analogRead(A8);
// controllerData.analogAxisArray[9] = analogRead(A9);
// controllerData.analogAxisArray[10] = analogRead(A10);
// controllerData.analogAxisArray[11] = analogRead(A11);
// Because this is running in a loop, this end of the function will return the current status of all buttons and axes back to the loop.
return controllerData;
