Hi Guys
I am having a hard time using an Arduino Uno to control a 0V - 10V Damper actuator.
Below is the link to the specified actuator.
http://www.fmfranklin.com/data/siemens/gdb16-1-glb16-1.pdf
I have the actuator running off a 24V AC transformer and it does drive when manually adjusted so that hopefully rules out any problems with the actuator itself. The transformer output is then converted into DC via a rectifier and associated components. The final output Voltage is 24V DC. I then take that 24V DC and drop it down to 12V DC with a L7812CV. This 12V DC supplies the Arduino on the Vin & GND pins as well as the Op-amp.
I have managed to generate the 0 -10V DC signal by means of a Filter, Op-amp and a NPN transistor. The output voltage (0 - 10V) are are then sent to the actuator signal wire and it should move.
Do I have to ground the 0 to 10V signal with the AC 24V that powers the actuator?
Any help will be appreciated.
Thanks
