Required Help in coding to Store Multiple Byte In Arduino UNO By Serial.
hi ,
i am new to use arduino First time and required some help/tips to store Multiple Bytes from Serial Read. i send 232 bytes from my vb App to Arduino by Serial then Read but its store 1 character at a time . Mean split value . like when i send 217 decimal value from application, arduino store 1 then 2 and then 7 . when i read the stored data in application i see arduino store it 1 character per byte.
217 is actually 8bit (1101 1001) in my application and i convert bits in to byte and send to arduino.
Here is my arduino code :
char serInString[232];
int  serInIndx  = 0;
int  serOutIndx = 0;
const int  buttonPin = 2;
int buttonState = 0;
int lastButtonState = 0;
void readSerialString () {
    int sb;
    if(Serial.available()) {
      while (Serial.available()){
         sb=Serial.read();
         serInString[serInIndx] =sb;
         serInIndx++;
void printSerialString() {
   if( serInIndx > 0) {
      for(serOutIndx=0; serOutIndx < serInIndx; serOutIndx++) {
          Serial.print( serInString[serOutIndx] );
      serOutIndx = 0;
      serInIndx  = 0;
  pinMode(buttonPin, INPUT);
   serOutIndx=0;
void loop () {
readSerialString();
buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState) {
    if (buttonState ==HIGH) {
      Serial.println(serInString[serOutIndx]);
      else {
        serOutIndx++;
lastButtonState = buttonState;
Serial.parseInt();
See: https://www.arduino.cc/en/Reference/Serial
Is the order jumbling deliberate?
Dear johnwasser thanks for your idea but same result problem not solve .... :confused:
OK, thanks for letting us know. Good luck.
mrsheikh: Dear johnwasser thanks for your idea but same result problem not solve .... :confused:
and the code you used is what ?
