Hello,
I need your help guys, I am sending a number on serial monitor and it will generate that amount of frequency on Digital Oscilloscope. I am referring this link of Arduino Due Waveform Generator
I have to modify this code using two method
- Resampling, Linear Interpolation
2)Timer Interrupt
I have made certain modification, I guess my Code is not right.
Please find the attachment of my code.
/*Simple Waveform generator with Arduino Due
* connect two push buttons to the digital pins 2 and 3
with a 10 kilohm pulldown resistor to choose the waveform
to send to the DAC0 and DAC1 channels
* connect a 10 kilohm potentiometer to A0 to control the
signal frequency
Code Impelementation with AttachInterrupt Function
#include "Waveforms.h"
#define oneHzSample 1000000/maxSamplesNum // sample for the 1Hz signal expressed in microseconds
#define SAMPLE_RATE 44100.0
// Pin Connection
const int button0 = 2, button1 = 3;
volatile boolean state=LOW;
float number;
//Initialization of Wave
volatile int wave0 = 0, wave1 = 0;
int i = 0;
int sample;
void TC4_Handler() //Interrupt at 44.1KHz rate (every 22.6us)
TC_GetStatus(TC1, 1); //Clear status to fire again the interrupt.
analogWrite(DAC0, waveformsTable[wave0][i]);
analogWrite(DAC1, waveformsTable[wave1][i]);
// Variables will change:
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
int buttonState1; // the current reading from the input pin
int lastButtonState1 = LOW; // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 5; // the debounce time; increase if the output flickers
long lastDebounceTime1 = 0; // the last time the output pin was toggled
long debounceDelay1 = 5; // the debounce time; increase if the output flickers
analogWriteResolution(12); // set the analog output resolution to 12 bit (4096 levels)
analogReadResolution(12); // set the analog input resolution to 12 bit
pinMode(button0,INPUT);
pinMode(button1,INPUT);
pinMode(DAC0,OUTPUT);
pinMode(DAC1,OUTPUT);
//turn on the timer clock in the power management controller
pmc_set_writeprotect(false);
pmc_enable_periph_clk(ID_TC4);
//we want wavesel 01 with RC
TC_Configure(TC1, 1, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK2);
TC_SetRC(TC1, 1, 238); // sets <> 44.1 Khz interrupt rate
TC_Start(TC1, 1);
// enable timer interrupts on the timer
TC1->TC_CHANNEL[1].TC_IER=TC_IER_CPCS;
TC1->TC_CHANNEL[1].TC_IDR=~TC_IER_CPCS;
//Enable the interrupt in the nested vector interrupt controller
//TC4_IRQn where 4 is the timer number * timer channels (3) + the channel
//number (=(1*3)+1) for timer1 channel1
NVIC_EnableIRQ(TC4_IRQn);
analogWrite(DAC0,0);
analogWrite(DAC1,0);
// Read the the potentiometer and map the value between the maximum and the minimum sample available
// 1 Hz is the minimum freq for the complete wave
// 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
sample = constrain(sample, 0, oneHzSample);
Serial.println("Enter a number: ");
while(Serial.available()==0){}
number=Serial.parseFloat();
Serial.println(number);
//Mathematical calculation
float j= number* 367.5; // 367.5 = 44100/120
Serial.println(j);
float k=j/120;
Serial.println(k);
float l=k-int(k);
Serial.println(l);
i=l*120;
Serial.println(i);
wave0Select();
wave1Select();
i++;
if (i == maxSamplesNum) // Reset the counter to repeat the wave
i = 0;
// delayMicroseconds(number); // Hold the sample value for the sample time
// function hooked to the interrupt on digital pin 2
void wave0Select() {
int reading = digitalRead(button0);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// Function call Wave0Select
if (buttonState == HIGH) {
wave0++;
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState = reading;
if(wave0 == 4)
wave0 = 0;
// function hooked to the interrupt on digital pin 3
void wave1Select() {
int reading1 = digitalRead(button1);
if (reading1 != lastButtonState1) {
lastDebounceTime1 = millis();
if ((millis() - lastDebounceTime1) > debounceDelay1) {
if (reading1 != buttonState1) {
buttonState1 = reading1;
if (buttonState1 == HIGH) {
wave1++;
lastButtonState1 = reading1;
if(wave1 == 4)
wave1 = 0;
Thanks in advance!!
