Hi!
I have a problem with my due. The reset button is not working. I tried to test it using a simple Serial write sketch…
Does anyone know why or how to fix this?
I noticed this as I was testing my Displayshield. Somehow it only showed something as I flashed the sketch to the Chip, after connecting/disconnecting the Arduino it was just showing a white screen.
int led = 13;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
Serial.println("reboot succesfull!");
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Serial.println("not rebooting :(");
