Reset button to run program A or B
Hi
It is possible to switch two programs (A , B ) using reset button.
1.press just reset button - program B is running.
2. Pressing button on PB9 an holding it, then press reset button - program A is running.
  pinMode(PB9, INPUT_PULLUP);
  if (digitalRead(PB9) == LOW)// while  arduino reset button is pressed
    run program A
    run program B
Program A
const int analogIn = PA6;
#include <LiquidCrystal.h>
//LiquidCrystal lcd(PB15, PB5, PA2, PB6, PB8, PB9);
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
float val = 0;// define the variable as value=0
  lcd.begin(16, 2);
val = analogRead(PA6);
 // val = val / 1024 * 5.0; // Convert the data to the corresponding voltage value in a math
  Serial.println(val);//Print the number of val on the serial monitor
  lcd.setCursor(0, 0);
  lcd.print(val,1);//Print the number of val on the LCD
 // delay(200); //Wait for 200ms
program B
/*https://create.arduino.cc/projecthub/jasirtp/arduino-frequency-counter-with-16x2-lcd-display-c99779
long microSecs;
long freq;
int lastBit;
int nowVal;
long secs;
long maxHz;
long minHz;
long minmax;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Loading...");
  pinMode(PA7,INPUT);
  pinMode(PA6,OUTPUT);
  microSecs = micros();
  freq = 0;
  lastBit = 0;
  nowVal =0;
  maxHz=0;
  minHz=0;
  minmax=0;
  secs = millis();
  //Serial.begin(9600);
int x=0;
  if ((microSecs+20)<micros()){
      nowVal=digitalRead(PA7);
      if (lastBit!=nowVal) {
        lastBit=nowVal;
        freq=freq+1;
      if (freq>maxHz){
        maxHz=freq;
      if (freq<minHz){
        minHz=freq;
      //lcd.clear();
      //lcd.print();
  if (secs+1000<millis()){
    if (minmax+300000<millis())
      minmax=millis();
      minHz=freq;
      maxHz=freq;
      lcd.clear();
      lcd.print((freq/2));
      lcd.print(" Hz");
      lcd.setCursor(0,1);
      lcd.print("+: ");
      lcd.print(maxHz);
      lcd.print(" -: ");
      lcd.print(minHz);
      freq=0;
      secs=millis();
Do you have a question?
Timing should be done with unsigned long
I'm sure a way could be figured out with an Uno. I am, also, sure that by the time all the hardware is purchased, put together, and debugged and the code written and debugged that buying an extra Uno to run the other thing would be more cost effective and less time consuming.
You would have to have both programs inside of one main program (as functions). You could store a variable in EEPROM that tells the main program which of the programs (functions) to run at start up. Then if you run program A at reset, change the variable to run program B and store the variable in EEPROM so that the B program will run at the next reset.
You could use an ESP32 and A load both programs in to run with a button selection or B, create/destroy tasks on the fly to completely reload a new environment with the push of a button. No resetting required.
Learning curve, months. ESP32 <10.00USD.
bool RunA;
  pinMode(9, INPUT_PULLUP);
  RunA = digitalRead(9) == HIGH;
  if (RunA)
    setupA();
    setupB();
  if (RunA)
    loopA();
    loopB();
const int analogIn = A6;
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
void setupA()
  lcd.begin(16, 2);
void loopA()
  val = analogRead(A6);
  lcd.print(val, 1); //Print the number of val on the LCD
long microSecs;
long freq;
int lastBit;
int nowVal;
long secs;
long maxHz;
long minHz;
long minmax;
void setupB()
  lcd.begin(16, 2);
  pinMode(A7, INPUT);
  pinMode(A6, OUTPUT);
  freq = 0;
  lastBit = 0;
  nowVal = 0;
  maxHz = 0;
  minHz = 0;
  minmax = 0;
  secs = millis();
int x = 0;
void loopB()
  if ((microSecs + 20) < micros())
    nowVal = digitalRead(A7);
    if (lastBit != nowVal)
      lastBit = nowVal;
      freq = freq + 1;
    if (freq > maxHz)
      maxHz = freq;
    if (freq < minHz)
      minHz = freq;
    //lcd.clear();
    //lcd.print();
  if (secs + 1000 < millis())
    if (minmax + 300000 < millis())
      minmax = millis();
      minHz = freq;
      maxHz = freq;
    lcd.clear();
    lcd.print((freq / 2));
    lcd.print(" Hz");
    lcd.setCursor(0, 1);
    lcd.print("+: ");
    lcd.print(maxHz);
    lcd.print(" -: ");
    lcd.print(minHz);
    freq = 0;
    secs = millis();
Big thanks, it is working.
It is possible to switch //#define SAMPLES in this program using 5 different buttons
#include "LiquidCrystal.h"
//#define SAMPLES 57
#define SAMPLES 40
//#define SAMPLES 41
//#define SAMPLES 42
//#define SAMPLES 43
 #include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag1 = 0;
int flag2 = 0;
int out1 = PB7;
int out2 = PA8;
int val1[SAMPLES];
int val2[SAMPLES];
int16 shift = 0;
 int ovfi;
int amp = 35;
int cnt = 0;
int time_track = 0;
float stp = 6.2831/SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
timer_dev *dev2 = PIN_MAP[out2].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
uint8 cc_channel2 = PIN_MAP[out2].timer_channel;
void fun()
    flag1++;
void fun2()
    flag2++;
void timer_conf()
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
  timer_dma_set_base_addr(dev2, TIMER_DMA_BASE_CCR1);
  timer_dma_set_burst_len(dev2, 1);
  timer_dma_enable_req(dev2, cc_channel2);
  timer_set_reload(dev2, 102);
  timer_set_prescaler(dev2, 0);
void dma_conf()
    dma_init(DMA1);
    /* T4C2 DMA C4 */
    dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
    dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
    dma_cfg.tube_src = val1;
    dma_cfg.tube_src_size = DMA_SIZE_32BITS;
    dma_cfg.tube_nr_xfers = SAMPLES;
    dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
    dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
    dma_cfg.target_data = 0;
    ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
    /* T1C1 DMA C2 */
    dma_cfg.tube_dst = &(dev2->regs.gen->DMAR);
    dma_cfg.tube_src = val2;
    dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH1;
    ret = dma_tube_cfg(DMA1, DMA_CH2, &dma_cfg);
void dma_start()
  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_attach_interrupt(DMA1, DMA_CH2, fun2);
  dma_enable(DMA1, DMA_CH2);
  timer_resume(dev2);
void init_wave()
  int i;
  for(i=0;i<SAMPLES;i++)
      val1[i] = 50 + amp * sin(stp * i);
      val2[i] = val1[i];
void get_wave(int16 shift)
   int i;
  int ovfi;
    ovfi = 1000 - i;
      val2[i] = 50 + amp * sin( stp * i + shift * 0.1 * 6.2831 / 360);
   lcd.begin(16, 2);
int i;
  pinMode(out1, PWM);
  pinMode(out2, PWM);
  lcd.print("SAMPLES ");
    lcd.print(SAMPLES );
#define macro substitution is a pre-compilation step, you can't change them at runtime, so your assertion is false.
Not easily. The arrays are static and the size has to be a compile-time constant. The state of the buttons is only available at run time. You would have to change your arrays from statically allocated to dynamically allocated. That will take some research on your part.
How about adding program C ?
What does that mean?
A third program
Sure. Pick another input pin. In setup(), set a global variable to one of three (or four) values based on the state of the input pins . Then, still in setup(), call the chosen setupN(). In loop() call the chosen loopN().
I did this way, error - 'setupC' was not declared in this scope
bool RunA;
  RunA = digitalRead(PB9) == HIGH;
  if (RunA)
    setupA();
    setupB();
  pinMode(PB8, INPUT_PULLUP);
  RunA = digitalRead(PB8) == HIGH;
  if (RunA)
    setupA();
    setupC();
  if (RunA)
    loopA();
    loopB();
    loopC();
//A
//LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
void setupA()
  lcd.begin(16, 2);
void loopA()
//B
long microSecs;
long freq;
int lastBit;
int nowVal;
long secs;
long maxHz;
long minHz;
long minmax;
void setupB()
  lcd.begin(16, 2);
  pinMode(PA7, INPUT);
  pinMode(PA6, OUTPUT);
  freq = 0;
  lastBit = 0;
  nowVal = 0;
  maxHz = 0;
  minHz = 0;
  minmax = 0;
  secs = millis();
int x = 0;
void loopB()
    nowVal = digitalRead(PA7);
      lastBit = nowVal;
      freq = freq + 1;
    if (freq > maxHz)
      maxHz = freq;
    if (freq < minHz)
      minHz = freq;
    //lcd.clear();
    //lcd.print();
      minmax = millis();
      minHz = freq;
      maxHz = freq;
    lcd.clear();
    lcd.print(" Hz");
    lcd.print("+: ");
    lcd.print(maxHz);
    lcd.print(" -: ");
    lcd.print(minHz);
    freq = 0;
    secs = millis();
// C
#define SAMPLES 100
struct debounce_info
  int start, state;
  int16 shift;
}  up, down;
int flag1 = 0;
int flag2 = 0;
int out1 = PA10;
int out2 = PA8;
int val1[SAMPLES];
int val2[SAMPLES];
int ampp = PB9;
int ampn = PB6;
//int ampn = PB11;
int16 shift = 0;
int amp = 35;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
void fun()
  flag1++;
void fun2()
  flag2++;
void timer_conf()
void dma_conf()
  dma_init(DMA1);
  /* T1C3 DMA C4 */
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH3;  //T1C3, PA10
  // ampl
  /* T1C1 DMA C2 */
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM1_CH1; // T1C1,PA8
void dma_start()
  timer_resume(dev1);
  dma_attach_interrupt(DMA1, DMA_CH2, fun2); //PA8
  timer_resume(dev2);
void init_wave()
  int i;
  for (i = 0; i < SAMPLES; i++)
    val2[i] = val1[i];
  int i;
      val1[i] = 50 + amp * cos( stp * i + shift * 0.1 * 6.2831 / 360);
  pinMode(out1, PWM);
  pinMode(out2, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
void loopC()
Did you forget a C there?
Thanks, this error is gone, I have a new one from this part
  if (RunA)
    loopA();
    loopB();
    loopC();
error
'else' without a previous 'if'
An if/else is a binary proposition.
If something is true then do this, else (otherwise) do something (one other thing) else.
Maybe try switch/case,or another if
Now I have no errors, but pin PB9 is not working
bool RunA;
  if (RunA)
    setupA();
    setupB();
  if (RunA)
    setupA();
    setupC();
  if (RunA)
    loopA();
    loopB();
    if (RunA)
    loopA();
    loopC();
Can you just slow down and start thinking?
If runA is LOW, you'll run loopB and loopC
"not working" in what way, exactly?
