Hee guys,
Does anyone know how I can reset the button presses to 0 every 10 seconds.
int LED = D7; // digital pin D6
int BUZZER = D6;
int BUTTON = D2; // digital pin D2
int buttonPressed = 0; // default value for times that button is pressed
bool toggleButton = true; // var to check if the button has been clicked
// setup() runs once, when the device is first turned on.
// Initialization of pinModes
pinMode(BUTTON, INPUT);
pinMode(LED, OUTPUT);
pinMode(BUZZER, OUTPUT);
// loop() runs over and over again, as quickly as it can execute.
// read value of input pin
if (digitalRead(BUTTON) == HIGH)
if (toggleButton)
buttonPressed ++;
// turn of the trigger of the button click to avoid trigger in next loop until releasing
toggleButton = false;
// check if button is pressed 3 times or more
if (buttonPressed > 1)
// write outputvalues, set to high
digitalWrite(LED, HIGH);
digitalWrite(BUZZER, HIGH);
delay(2000);
buttonPressed = 0;
// write outputvalues, set back to low
digitalWrite(LED, LOW);
digitalWrite(BUZZER, LOW);
// button has been released, so trigger can be catched again in next loop
