clift
January 29, 2022, 4:46am
1
I am a using an ultrasonic sensor to detect how long ago an object was placed. I need to reset the "countUp" variable. My code is provided bellow if anyone has a solution?
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
int countUp;
Serial.print(countUp);
Serial.println(" Seconds Since Object Placed");
if (sr04.Distance() < 5)
countUp++;
int countUp = 0;
Serial.print("Reset");
LarryD
January 29, 2022, 4:49am
2
countUp = 0;
clift
January 29, 2022, 4:54am
3
Sorry, but what changed, if it is the:
int countUp = 0;
to
int countUp = 0;
I got this error: expected '}' at end of input
That creates a completely new countUp variable that is different from the countUp variable declared before setup(). It only lives (is in scope) in the else structure.
See here for more on scope .
clift
January 29, 2022, 5:02am
5
Error code: 'countUp' was not declared in this scope
int countUp = 0; declares a new variable by the name countUp and assigns the value 0.
countUp = 0; assigns a value of 0 to a variable named countUp.
All that you needed to do remove the int from in front of countUp in the else structure.
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN, TRIG_PIN);
int countUp;
countUp++;
countUp = 0; // remove the int
You were missing the } to close the loop() function.
...which is exactly why I said:
When you compile and run it, it doesn't perform like you want...
econjack
