reset micros() timer
Is it possible to reset the micros() values to 0, if so, how do I do it? What will it break? Specifically interested in any effect on hardware serial. Thank you
First things, first. You need to explain WHY you (think you) need to reset micros()'s output.
There are almost always better ways.
Instead of resetting, I would like to be able to preset the internal counters. Is it possible?
Cheers, Kari
Why?
Its probably a dumb idea, but that hasn’t always stopped me in the past.
I’m triggering two axes of stepper motors that have to move in sync but at arbitrary speeds in real time.
So I’m looping on something like
if(currentx != targetx)
if(next_x < micros())
stepx()
next_x += x_delay_period
And I feel like I’m coming close to the limit of what I can push through in terms of real time step rate while still catching all the serial traffic
This is more of a silly nit picky thing though, I don’t want to have to check for overflows once per microstep per axis
I know bad practice is bad practice but I don’t expect the bounds of the project to grow and if it wont actually break anything that I’m using then it would give me a little warm feeling to do it this way
someone please chastise some sense into me
jstkatz:
       stepx()
Your code is flawed, and if you do it properly, you’ll never have to worry about overflows. Here’s how to do it properly:
    // Variables to remember last waiting period.
    // Those need to be static and of type unsigned long
    static unsigned long start_x = 0;
    static unsigned long start_y = 0;
    unsigned long curtime = micros();
    if (curtime - start_x >= delay_x) {
        ... do something useful with x axis ....
        // Reset timer for x
        start_x = curtime;
    if (curtime - start_y >= delay_y) {
        ... do something useful with y axis ....
        // Reset timer for y
        start_y = curtime;
That’s it. The important parts to remember is to never compare values you get from millis() or micros() or add delays to those values, because that will fail at the overflow. Always substract the current time from the starting time and compare the difference against the expected period so that the subtraction will take care of the overflow for you.
Korman
No need. Post your Sketch. I suspect you will receive a fairly simple revision that is immune to the overflow.
[quote author=Coding Badly link=topic=57562.msg413931#msg413931 date=1301985175]
Why?
[/quote]
C'moon, don't ask "why" when I ask is it possible? :)
Cheers, Kari
GaryP: C'moon, don't ask "why" when I ask is it possible?
If you need to ask if it's possible, you shouldn't do it. If you know how to do it, then you won't want to do it because you'd understand why it's a bad idea and what problems you'd create by doing it. You'd also know how to handle those variables correctly and see no reason to such a thing.
In short, telling someone who asks that question how to do it is in 100% of all cases the wrong thing to do. Better assume that you can't change those counters and resolve your problems the correct way.
Korman
Korman:
Korman
My friends!
I don't understand your why you guys keep saying such a thing. I do take care of the logic in my programs, I just would like to do some things my way, if there's a way.
Simple example could be, that I wan't to avoid calculating difference between counter and external input. Let's say resetting internal timer to match with imaginative time, no RTC or GPS, only manual input. I try to avoid the need of extra functions for that.
I take your answer as you don't like the idea, but it won't help me. And if you don't know how to do it, it is ok.
Thanks for taking care of me and my application anyway, your consern is delightful.
For the Future! I want to highlight one thing. I don't like pissing contest, who's argument is the last , it is not taking us anywhere. I have noticed that there's some attitudes and ways to express ourselves, that sounds sometimes a little moody (is this a real word?). I'm doing my best to correct this personaly, I've been feeling that this attitude is quite catching. When novices, newcomers, asks a question, there's a temptation to give quick and harsh answer, just because the same question has been asked 1001 times before, and every new person introduces themselves "HELP ME I'M N00B!". If we have an answer, why hide it or be rude other ways.
So, I like to know different methods to do different things, if there's a good reason to avoid something, please, arguments are always welcome. Just don't think the inquirer is stupid, I have seen that the case is not always that. ;)
Cheers, Kari
GaryP: I don't understand your why you guys keep saying such a thing.
Because you ask the wrong questions.
GaryP: Simple example could be, that I wan't to avoid calculating difference between counter and external input.
So instead you prefer to mess around with linker values so that you can access the right variable and then also add the appropriate assembly instructions so that you don't get variable corruptions in case of simultaneous access by the ISR function. If you know how to do that on your own, that may be a useful option. But if you don't, messing around in that area is so completely out of your depth that nothing good will come from it. It's a just like cutting you arm off to clean your nails simply because you don't like bending your elbow and you come and ask how best to cut your arm off.
GaryP: I take your answer as you don't like the idea, but it won't help me.
No, it has nothing to do with liking, it's all about knowing. I know that someone asking a question like this shouldn't do it. That's experience speaking. If you had a valid reason to reset the micros() timer, you'd ask completely different questions.
Korman
Great analogy!
@GaryP: It isn't about a p155ing contest, it is about experience.
There is a programming adage that goes something like "For every problem there is a solution that is simple, elegant efficient...and wrong".
It is very easy to (p)reset the timers; much harder though to do it correctly. Once you set out down the path towards the Dark Side, it can be very hard to retrace your footsteps.
You'd also know all the places where the micros() timer is used, and all the things that would be impacted when you changed the micros() timer. And, therefore, you'd know that you should not be messing with the micros() timer.
And you'd know how to do it because you would have examined its code in the process....
Basically micros() is potentially used by any library your sketch uses, so altering it could break them. Its trivial to implement your own resettable version on top of micros():
long my_datum = 0L ;
long myMicros ()
  return micros() - my_datum ;
void myReset ()
  my_datum = micros () ;
Korman, stop the rage, you are scary! :astonished:
Thanks you all, arguments taken, and I will forget my original idea completely.. for now. But the deeper knowlegde is there waiting.
Cheers, Kari
Hmmm.
Actually some of the more difficult concepts of arduino hardware and software are best explained during some of the great 'pissing contests' I've read here. For me I don't care about who is right and who is wrong, (even if it's me ;) ) as long as I've learned something useful when it's all done. The Arduino platform, being open sourced, has all the code avalible to study but that can be a daunting task to figure out for some of us software challenged types. It's cool to read explanations from people that have looked it over and can give concise explanations.
As far as being hard on newcomers, I have been hard on some in the past when they touch my sensitive spot about HAVING to use series current limiting resistors with diodes. I don't start right off flaming, but if they offer any resistance to my fatherly advice I tend to lose patience. :D
Lefty
retrolefty: ...I don't start right off flaming, but if they offer any resistance to my fatherly advice I tend to lose patience. :D
Sure, everyone needs two chances... and then KABOOM.
Have I used both of mine already? Just kidding, of course I have.
Cheers, Kari
After a Kaboom, the chance counter is reset. That’s easier to do than resetting the micros counter. so don’t worry.
Korman
That's cool! Let's continue with the mission!
Cheers, Kari
