Reset Serial?
Greetings,
I have an Arduino Mega with two incoming serial signals.
It works great, but I have to disconnect my serial devices until after it boots, otherwise it never comes online.
Can anyone recommend what I can do to avoid having to disconnect the serial devices on boot?
I am just reading the bytes like:
    if (Serial1.available()) {
        byteSer1=Serial1.read();
    if (Serial2.available()) {
        byteSer2=Serial2.read();
Thank you!
I assume that one of these serial inputs is on the hardware serial pin 0. Presumably that's the boot loader getting in on the act, thinking that a sketch is on the way. AFAIK you can't stop it, maybe you'll have to flash your program into a clean chip.
Rob
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1204641836
@Bob:- that link is the auto reset on the main serial connection. This seems to be a problem with two of the extra serial ports on a mega, not the main one which is still called serial (not serial1).
Aah the MEGA, sorry didn't spot that. In that case there's no reason for this to happen. Is there a shared interrupt somewhere and the Mega boot loader was never tested with incoming serial on the other ports?
Rob
Weird! I wonder if it has to do with the WiShield.
Is it possible to run Serial1.begin(9600) in the loop()?
