Reset the counters after a second press of the button.
Good morning,
I'm having trouble with the Arduino code:
I would like that after pressing a second time...
all the storytellers reset themselves ( DOCounter ; Dtemps ; SDtemps ; DOtime ; SDOtime ; DOTotaltime ; SDOTotaltime ; DOpercent ; )
and also we add 1 in the counter (Operation).
At the moment only (DOCounter) is reset.
The other counters don't reset. And there is no +1 added to (Operation)
Thank you very much for helping me if possible.
Wiring and Result in attachment.
// this constant won't change:
const int buttonPin = 2;  // the pin that the pushbutton is attached to
const int doorPin = 3;    // the pin that the pushbutton is attached to
const int ledPinbutton = 13;  // the pin that the LED is attached to
const int ledPindoor = 12; //
// Variables will change:
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int DeviceState = 0; // current state of DEVICE
int buttonPushCounter = 0; // counter for the number of button presses
unsigned int DOCounter = 0;   // counter for the number of Door Opened
unsigned int Operation = 0; //
int doorState = 0;         // current state of the Door
int lastdoorState = 0;     // previous state of the Door
unsigned long Dtemps = 0; //  Duration of the operation
unsigned long SDtemps = 0; // Duration of the operation in second
unsigned long DtimeO = 0; // Exact time the door is opened
unsigned long SDtimeO = 0; // Exact time the door is opened in seconds
unsigned long DtimeC = 0; // Exact time the door is closed
unsigned long SDtimeC = 0; // Exact time the door is Closed in seconds
unsigned long DOtime = 0; // Door Previous opening time
unsigned long SDOtime = 0; // Door Previous opening time in seconds
unsigned long DOTotaltime = 0; // Cumulative time of all Door openings
unsigned long SDOTotaltime = 0; // Cumulative time of all Door openings in seconds
float DOpercent = 0; // Percentage of door opening time
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the door pin as a input:
  pinMode(doorPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPinbutton, OUTPUT);
  pinMode(ledPindoor, OUTPUT);
  // initialize serial communication:
  Serial.println( " Starting the program: Hello ... ");
  Serial.println(" ");
  Serial.println("*****************************************************************************");
  Serial.println("  Ope  |  Opn  | D. O .T. | D. C. T. |  D. O.  | C. D. O. | D. S. O. |   %   ");
  Serial.println("-----------------------------------------------------------------------------");
} //void setup
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      buttonPushCounter++;
     } //if (buttonState == HIGH)
   } //if (buttonState != lastButtonState)
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // First Press
      if (buttonPushCounter % 2 == 1) {
        //turn LED BUTTON ON:
        digitalWrite(ledPinbutton, HIGH);
        Dtemps = millis(); // Exact time the operation began
      doorState = digitalRead(doorPin);
      // compare the DoorState to its previous state
      if (doorState != lastdoorState) {
        if (doorState == LOW) {// if the door is Open
            DOCounter++; // Adds 1 to the counter
            // turn LED DOOR ON:
            digitalWrite(ledPindoor, HIGH);
            DtimeO = millis(); // Exact time the door is opened
         } //if (doorState == LOW)
           else { // door is closed
          // turn LED DOOR OFF:
          digitalWrite(ledPindoor, LOW);
          // if the current state is LOW then the button went from on to off:
          SDtemps = 0.001 * Dtemps; // Expression of time in seconds
          SDtimeO = 0.001 * DtimeO; // Expression of time in seconds
          DtimeC = millis(); // Exact time the door is closed
          SDtimeC = 0.001 * DtimeC;// Expression of time in seconds
          DOtime = DtimeC - DtimeO; // Calculation of door opening time
          SDOtime = 0.001 * DOtime; // Expression of time in seconds
          DOTotaltime = DOTotaltime + DOtime; // Calculation of the total duration of all door openings
          SDOTotaltime = 0.001 * DOTotaltime; // Expression of time in seconds
          float fDtimeC = (float)DtimeC; // Conversion to Float
          float fDOTotaltime = (float)DOTotaltime; // Conversion to Float
          DOpercent = 100 * (fDOTotaltime / fDtimeC); // percentage calculation
          // Display values
            // Ope:
                 if (Operation < 10){Serial.print("     ");}
            else if (Operation < 100){Serial.print("    ");}
            else if (Operation < 1000){Serial.print("   ");}
            Serial.print(Operation);
            Serial.print(" |");
            // Opn:
                 if (DOCounter < 10){Serial.print("     ");}
            else if (DOCounter < 100){Serial.print("    ");}
            else if (DOCounter < 1000){Serial.print("   ");}
            Serial.print(DOCounter);
            Serial.print(" |  ");
            // D. O. T.
                 if ( SDtimeO < 10){ Serial.print("    ");}
            else if ( SDtimeO < 100){ Serial.print("   ");}
            else if ( SDtimeO < 1000){ Serial.print("  ");}
            else if ( SDtimeO < 10000){ Serial.print(" ");}
            Serial.print(SDtimeO);
            // D. C. T.
                 if ( SDtimeC < 10){ Serial.print("    ");}
            else if ( SDtimeC < 100){ Serial.print("   ");}
            else if ( SDtimeC < 1000){ Serial.print("  ");}
            else if ( SDtimeC < 10000){ Serial.print(" ");}
            Serial.print(SDtimeC);
            // D. O.
                 if ( SDOtime < 10){ Serial.print("     ");}
            else if ( SDOtime < 100){ Serial.print("    ");}
            else if ( SDOtime < 1000){ Serial.print("   ");}
            else if ( SDOtime < 10000){ Serial.print("  ");}
            Serial.print(SDOtime);
            // C. D. O.
                 if ( SDOTotaltime < 10){ Serial.print("     ");}
            else if ( SDOTotaltime < 100){ Serial.print("    ");}
            else if ( SDOTotaltime < 1000){ Serial.print("   ");}
            else if ( SDOTotaltime < 10000){ Serial.print("  ");}
            Serial.print(SDOTotaltime);
            // D. S. O.
                 if ( SDtemps < 10){ Serial.print("     ");}
            else if ( SDtemps < 100){ Serial.print("    ");}
            else if ( SDtemps < 1000){ Serial.print("   ");}
            else if ( SDtemps < 10000){ Serial.print("  ");}
            Serial.print(SDtemps);
                 if ( DOpercent < 10){ Serial.print("  ");}
            else if ( DOpercent < 100){ Serial.print(" ");}
          Serial.println(DOpercent);
           } //else
    }  //if (doorState != lastdoorState)
      lastdoorState = doorState;
      } // if (buttonPushCounter % 2 == 1)
   // Second Press
   if (buttonPushCounter % 2 == 0) {
       // turn LED BUTTON OFF:
       digitalWrite(ledPinbutton, LOW);
     Operation = Operation++ ; // Adds 1
     DOCounter = 0;
     Dtemps = 0;
     SDtemps = 0;
     DOtime = 0;
     SDOtime = 0;
     DOTotaltime = 0;
     SDOTotaltime = 0;
     DOpercent = 0;
     } //(buttonPushCounter % 2 == 0)
 delay(10);
} //void loop
Wrong:
Right:
