Reset Value Received IR sensor
I really need to bring that once lost signal DigitalWrite (13, HIGH) for example.
I can not reset the value received from IR and basically when I click once the value remains the same
Is the code I tried to write:
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  pinMode(13, OUTPUT);
  if ((irrecv.decode(&results)) == 0)
    digitalWrite(13, HIGH);
Actually it is the basis for the project I want to make, and without this code lost all my project.
Thanks :slight_smile:
You could read the millis timer when you turn the LED on, then some time later, turn it off.
AWOL:
Can you please write down the code?
I could write it down, but what would be the point?
Can you have a look at the blink without delay example?
