Reseting a variable to 0
Hi all. I've been having some difficulties with this issue and I can't find a good source to explain me what to do in this situation, so I decided to post it here as it has solved some other problems that I had in the past.
What I'm trying to do here is to make work a DC motor by pressing one of the keys of the computer keyboard (number 1), and turning it off with the same key. To do that, what I do is create a variable, and when I press the key, add 1 to that variable. Now the variable is equal to 1. Once I press again the same key on the pc computer, the variable should reset to 0 so the motor stops, but this is where I fail to program.
I know there's various options, like when the variable surpases a certain number reset it back to 0 (what I tried), but It doesn't seem to work.
I use Arduino UNO and Motor shield R3 if that helps. If you need anything else, just ask. Thank you! Here's the code:
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  Serial.println("apreta 1 per anar endavant");
  Serial.println("apreta 2 per anar endarrere");
  char a = 0;
    if (Serial.available() > 0)
    a = Serial.read();
    if (a == '1')
       {(a++);
       if(a=2){
       a = 0;}
  if (a=1) {
       digitalWrite(12, LOW); //Establishes forward direction of Channel A
       digitalWrite(9, LOW);   //Disengage the Brake for Channel A
       analogWrite(3, 123);   //Spins the motor on Channel A at half speed
  if (a=0) {
        digitalWrite(9, HIGH);
 if(a=2){
You got the first one right, but not this comparison
AWOL: if(a=2){
If I had a dollar for every time I made that mistake.........
Or the next two. The quickest way to swap between 0 and 1 is to use
a=1-a; So if a == 0 you get 1 and if a == 1 you get 0.
Mark
Well I use
a = (a + 1) & 1;
the variable a will alternate between 0 and 1 every time this is executed as it will if a is initially 0 or 1 with this code
a = a^1;
if (a == '1')
  (a++);
  if(a=2)
     a = 0;
There are a few things wrong with this part aside from the previously mentioned errors with the if statement. '1' and 1 are the not the same as far as the micro controller goes, so it would be best not to mix them like you've done here. If a is '1', then you increment it (you don't need the parenthesis surrounding a++ by the way) to '2'. Now you are comparing it to 2. 2 and '2' are not the same. So say that issue is also fixed, you then run into a logical error of what happens the next time you hit the button after your reset a to '0'?
If I had a pound for every time I had to point it out...
Nothing, the motor keeps going. Sorry for being such a noob, I’m still learning :slight_smile:
How should the code look then?
Nothing,
So you changed the code and it won’t work. So post what you have changed it to and we can see where you haven’t understood what was said.
Okay, this is what I changed, but I'm not sure what you meant by caomparing the 2 and '2'
  char a = 0;
    a = Serial.read();
    if (a == '1')
    {a++;}
    if (a > 1)
    {a == 0;
Jaks13: Okay, this is what I changed, but I'm not sure what you meant by caomparing the 2 and '2'
First off, your coding style makes this very difficult to read. Use the Tools > Auto Format before posting your code to save our sanity.
2 and '2' are not equal. '2' is a character representation of 2 and has the equivalent decimal value of 50. When you fix the later mentioned error, you'll notice that if (a > 1) will always be true because anything you type into the serial monitor will have a binary value greater than 1. http://www.asciitable.com/
    a = Serial.read();
    if (a == '1')
      a++;
    if (a > 1)
      a == 0;
You're mixing = and == again. If you want to set the value of the left side variable, use =. If you want to compare the value on the left side to the value on the right side, use ==.
holmes4:
Mark
I prefer a = !a;
