Hello! I'm still unfamiliar with Arduino looping concept. I just got an assignment to connect Arduino with a keypad and LCD screen.
Here we can input a number to set the LED blink delay time. The task is: after inputting the first value, the LED will blink continuously, and by pressing "A" in the keypad, it should stop and accept another delay time value. However, in my case, I can't insert another value after inputting the first one. Here are the codes:
#include <Wire.h>
#include <Keypad.h>
int pin = 13;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','A' },
{'4','5','6','B' },
{'7','8','9','C' },
{'*','0','#','D' }
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad, row1,2,3,4
byte colPins[COLS] = {8, 9, 10, 11}; //connect to the column pinouts of the keypad col1,2,3,4
// initialize Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// check address, you can you IIC scan code to check
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
// input delay time
int delay_time = 0;
// set the pin mode for LED
pinMode(pin, OUTPUT);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// set the cursor in the first row and first column
lcd.setCursor(0, 0);
// Print a message to the LCD.
lcd.print("Delay time (ms):");
// set the cursor in the second row
lcd.setCursor(0, 1);
// input delay time in millisecond
delay_time = input();
// Turn off the LED:
digitalWrite(pin, LOW);
delay(delay_time);
// Turn on the LED:
digitalWrite(pin, HIGH);
delay(delay_time);
//Input Chars
//return: input number
int input()
unsigned int n=0; //holding no. of chars inputted
unsigned char tmp=0;
char input_temp[10];
int input_len=0, i;
tmp = keypad.getKey();
lcd.cursor(); //show cursor
lcd.blink(); //blink cursor
while(tmp != '#')
if(tmp == '*')
//Clear Data
lcd.rightToLeft();
for(i=0; i<n; i++)
lcd.print(" ");
lcd.leftToRight();
lcd.print(" ");
lcd.rightToLeft();
lcd.print(" ");
lcd.leftToRight();
n = 0;
else if(tmp != NO_KEY && tmp != '*')
input_temp[n++] = tmp;
lcd.print(input_temp[n-1]);
lcd.noCursor(); //no cursor
return convert_chars_to_int(input_temp, n);
}//end input_chars
//Convert Chars to integer
//Parameters: *buf: chars in string
// len: no. of chars
//return: a integer
int convert_chars_to_int(char *buf, int len)
int i, value=0, j=len;
for(i=0; i<j; i++)
value += (pow_int(10, --len) * (buf[i] - '0'));
return value;
}//end convert_chars_to_int
int pow_int(int base, int expo)
int value =1, i;
for(i=0; i<expo; i++)
value *= 10;
return value;
}//end pow_int
I've tried using another code model. It can reset the value after I pressed "A", however, the LED will only blink once. Can you guys give any suggestions about this? Thank you very much!
