Resetting LED's so not to have to reset each switch with Nano
Hello,
This is my first post on here I have a few projects going on and most likely will be on here quite often for now on. This post I am creating a small box with multiple LEDs and toggle switches coded with a Nano to motivate and reward my toddler son for getting ready in morning and before bed. The issue that is giving me problems is I would like to have one toggle seperate from the rest that when switched will reset all the leds to go off so that when other toggles are switched back it will turn LED back on as to not have to go through each toggle an reset everynight and day. I did write simple code jus to get the switch working and attempting to get it to work with code. I think I may just be brain dead at the moment was trying to make this SUPER difficult all day and only use logic gates and flip flops so been going over alot of data sheets and HOW TOs lol.
heres the code:
// declares LED pin and Switch pin
const int led = 2;
const int swt = 3;
const int restart = 4;
// Sets pins mode for output to pwr LED and input_pullup for
// resistor dedicated to switch to stop floating
  pinMode(led, OUTPUT);
  pinMode(swt, INPUT_PULLUP);
  pinMode(restart, INPUT_PULLUP);
 // reads switch pin for button press
  int button = digitalRead(swt);
// reads restart switch to flip inputs starts new day of chores
  int flip = digitalRead(restart);
  if (button == LOW && flip == LOW) {
    // puts LED pin in to low state to turn it off
    digitalWrite(led, LOW);
    Serial.println("button LOW, restart LOW");
  } else if (button == HIGH && flip == LOW) {
    // puts LED into high state to turn it on
    digitalWrite(led, HIGH);
    Serial.println("button HIGH, restart LOW");
  } else if (button == HIGH && flip == HIGH) {
    Serial.println("button HIGH, restart HIGH");
  } else Serial.println("button LOW, restart HIGH");
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
In point form, regular text, write out exactly the sequence of events.
See if you can follow this sketch:
// Version    YY/MM/DD    Description
// 1.00       22/11/03    Running sketch
#define CLOSED                        LOW
#define OPENED                        HIGH
#define PUSHED                        LOW
#define RELEASED                      HIGH
#define LEDon                         HIGH
#define LEDoff                        LOW
#define RELAYon                       LOW
#define RELAYoff                      HIGH
#define RUNNING                       true
#define notRUNNING                    false
#define ENABLED                       true
#define DISABLED                      false
const byte switch1                  = 2;  // +5V---[50k Pullup]---[Input Pin]---[Switch]---GND
const byte switch2                  = 3;
const byte switch3                  = 4;
const byte switch4                  = 5;
const byte switch5                  = 6;
const byte resetSwitch              = 7;
const byte led1                     = 8;  // +5V----[220R]----[A->|-K]----GND
const byte led2                     = 9;
const byte led3                     = 10;
const byte led4                     = 11;
const byte led5                     = 12;
const byte heartbeatLED             = 13;  // +5V----[220R]----[A->|-K]----GND
byte lastSwitch1State               = OPENED;
byte lastSwitch2State               = OPENED;
byte lastSwitch3State               = OPENED;
byte lastSwitch4State               = OPENED;
byte lastSwitch5State               = OPENED;
byte lastResetSwitchState           = OPENED;
//timing stuff
unsigned long heartbeatTime;
unsigned long switchTime;
const unsigned long toggleInterval  = 500ul;    //500ms
//                                       s e t u p ( )
  //set pins to inputs with pullup resistor enabled
  for (byte x = 2; x <= 7; x++)
    pinMode(x, INPUT_PULLUP);  // +5V---[50k Pullup]---[Input Pin]---[Switch]---GND
  //set pins to outputs
  for (byte x = 8; x <= 13; x++)
    pinMode(x, OUTPUT);       //+5V----[220R]----[A->|-K]----GND
    digitalWrite(x, LEDoff);
}  //END of   setup()
//                                        l o o p ( )
  //*************************************                     heartbeat T I M E R
  //to see if the sketch has blocking code,
  //toggle the heartbeat LED (every 500ms)
  if (millis() - heartbeatTime >= toggleInterval)
    //restart the TIMER
    heartbeatTime = millis();
    //toggle the LED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //*************************************                     switch T I M E R
  //is it time to check the switches ? (every 50ms)
  if (millis() - switchTime >= 50ul)
    //restart the TIMER
    switchTime = millis();
    //go and check the switches
    checkSwitches();
  //other non blocking code goes here
} //END of   loop()
//                              c h e c k S w i t c h e s ( )
void checkSwitches()
  byte currentState;
  //*************************************                     s w i t c h 1
  //switch1 code
  currentState = digitalRead(switch1);
  //was there a change in state ?
  if (lastSwitch1State != currentState)
    //update to the new state
    lastSwitch1State = currentState;
    //was the switch closed ?
    if (currentState == CLOSED)
      //toggle the LED
      digitalWrite(led1, !digitalRead(led1));
  } //END of this switch
  //*************************************                     s w i t c h 2
  //switch2 code
  currentState = digitalRead(switch2);
  if (lastSwitch2State != currentState)
    lastSwitch2State = currentState;
      //toggle the LED
      digitalWrite(led2, !digitalRead(led2));
  //*************************************                     s w i t c h 3
  //switch3 code
  currentState = digitalRead(switch3);
  if (lastSwitch3State != currentState)
    lastSwitch3State = currentState;
      //toggle the LED
      digitalWrite(led3, !digitalRead(led3));
  //*************************************                     s w i t c h 4
  //switch4 code
  currentState = digitalRead(switch4);
  if (lastSwitch4State != currentState)
    lastSwitch4State = currentState;
      //toggle the LED
      digitalWrite(led4, !digitalRead(led4));
  //*************************************                     s w i t c h 5
  //switch5 code
  currentState = digitalRead(switch5);
  if (lastSwitch5State != currentState)
    lastSwitch5State = currentState;
      //toggle the LED
      digitalWrite(led5, !digitalRead(led5));
  //*************************************                     r e s e t S w i t c h
  //resetSwitch code
  currentState = digitalRead(resetSwitch);
  if (lastResetSwitchState != currentState)
    lastResetSwitchState = currentState;
      //turn off all LEDs
      digitalWrite(led1, LEDoff);
      digitalWrite(led2, LEDoff);
      digitalWrite(led3, LEDoff);
      digitalWrite(led4, LEDoff);
      digitalWrite(led5, LEDoff);
} //END of   checkSwitches()
Hello jdubb9027
My summary is derived from your sketch:
You have a combination of n toggle switches and Leds.
Each toggle switch can light up the corresponding LED.
In addition to this combination, a toggle switch can switch off all Leds again.
Is this assumption correct?
If so, create an object for a toggle switch and LED combination. This object contains the data about the connection pins used. With a strucured array you can easily extend this to n combinations. A service will take this information to perform an action to light up the LED in this way. Next to this service, the "reset" toggle switch is also handled to clear all LEDs.
