Resetting Variable in for loop
I have a problem with my Code. I want to make a dynamic car blinker / indicator. The code needs to turn on the three lamps after the other one and then turning all lamps off and looping this process. In this code, the lamps go on after each other and go off but it doesnt loop so it just happens one time.
int led = 11;
int i = 1;
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
for(i; i<4; i+1){
digitalWrite(led,HIGH);
delay(50);
led=led+1;
delay(100);
i=i+1;
digitalWrite(11,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
Aufgabe7.3for.ino (337 Bytes)
for(i; i<4; i+1)Oops2
Please remember to use code tags when posting code
more clues C++ For Loop
i=i+1; at the end of for loop is the reason why your code does not work as expected.
You code can be rewritten as follows/
int led = 11;
int i = 1;
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  for (i = 0; i < 4; i++) {
    digitalWrite(led + i, HIGH);
    delay(150);
  digitalWrite(11, LOW);
  digitalWrite(12, LOW);
  digitalWrite(13, LOW);
See Arduino - for loop References
  for (i = 0; i < 4; i + 1) {
Oops
TheMemberFormerlyKnownAsAWOL:
Oops
I edited the code ^^
What about pin 14?
