So did you guys here the one about the machine that broke down because it had a resistor installed backwards from the manufacturer? I know I know.....I couldn't resist.
Haha
Was it one of these?
Hi, well if you put the resistor in the wrong way the value has changed.
I read my resistor colour codes left to right.
Resistor in wrong way means the value changes cos the colour code has.
This way you only need half the number of different value resistors in your parts tray.
Tom..... (When do we get our Karma back?)
PS A square peg will go in a round hole if the peg is small enough, or you use a bigger drill it.
(You can't put a square peg in a round hole....Didn't say it had to fit perfectly!!)
TomGeorge:
I read my resistor colour codes left to right.Resistor in wrong way means the value changes cos the colour code has.
What about Arabic or Hebrew readers? They would see a different value to you.
And doesn't it depend if your circuit's working on conventional current or actual electron flow?
Hi.
And I'm the southern hemisphere so the water goes down the plughole the other way too.
So many variables.....
Tom........
TomGeorge:
Hi.
You mean it goes UP the plughole?
Hi, yes....lol
We do a lot of recycling in this part of the world.
Spirals down plug hole, clockwise or anti-clockwise.\
Tom......
