Resistor Needed?
I'm going to use this voltage regulator in a project.
I'm going to trigger the shutdown pin with one of the Arduino PWM pins.
Do I need a resistor between the pin on the Arduino and the shutdown pin? I know this is standard when using a transistor as a switch.
Link is good?
Resistor probably not needed. Check the data sheet the current needed at the pin. Likely not 10s of mA.
