I just saw this resistor kit in the store: Arduino Official Store | Boards Shields Kits Accessories
Unfortunately its out of stock but I had a question about the 0 ohm cable. Is it just a regular cable or a special cable that makes sure that it doesnt let trough any ohms?
It's a piece of wire that looks like a resistor. They're used in the machines that fit components to pcbs, like if a jumper is required for some reason. The machines can't handle normal wire, so they use a 0 resistor which the machines can pick and place.
By the way, ohms don't get "let through". Coulombs are "let through" and that's what current is. Resistors, well, resist the passing of charge.
By my calculations a short jumper wire like that would actually be about 0.0015
ohms. IE zero ohms for the vast majority of purposes you might think of.
The only way to get true zero ohms is with superconductors.
No such thing as a zero ohm cable LOL. Sounds like clever marketing to me. In reality it is just so low it is not worth considering. Most cables are probably that way unless they are very long.
No, these things are very useful in professional electronics. They allow you to lay out PCBs with options, that is alternative functions that can be switched in and out when you are prototyping, they also tend to be left in on final production " just in case".
Would it look cooler if you connect two parts (like a bridge on top of a highway - currents don't get mixed up and wouldn't make shorts ) with a piece of wire or use a resistor ? Of course a resistor looks cooler and you won't have wires going everywhere . So you'd use these .
jarrod0987:
Yes .
Nothing is 0 Ohms (absolute zero) or infinite Ohms .
Professional marketing ?! I think buying this resistor is cheaper than buying a piece of wire to use instead .
And here I thought that they were giving you a special superconducting cable that comes with its own dewar flask to keep it at one degree above absolute zero.
No it is because you can put them in auto insertion machines, you can't do that with wire.
They are more useful with surface mount parts.
Still if you have never been in professional electronics then it might be hard to see it's usefulness. But it has saved many a "Cad spin" and even rescued some units in production.
So the jumper wire can be used as a resistor.
I’m trying to make a pause and play by using the arduino
In the image below is how it looks like.
In the code
int led = 7;
int fsr = A5;
int phone = 10;
pinMode(led, OUTPUT);
pinMode(phone, OUTPUT);
digitalWrite(phone, HIGH);
digitalWrite(led, HIGH);
int fsrRead = analogRead(fsr);
Serial.println(fsrRead);
if(fsrRead > 100){
digitalWrite(led, LOW);
digitalWrite(phone, LOW);
fsr is the pressure sensor.
When the pressure sensor is higher than 100 it will put the MIC OUTPUT LINE TO THE PHONE TOO LOW.
And the led is to check if if the code works.
The led is working but putting the mic output signal cable line to low is not working.
Unless i remove the cable by hand. When i put the cable back in the breadboard it is not playing the song again.
