Resistor vs Regulator vs Diode to stepdown DC to DC voltage?
Which one is better Resistor vs Regulator vs Diode to stepdown 5v dc (USB) to 3.3 dc voltage (webcam laptop module)?. And please give a simple explain. Thanks
To provide power to something that needs 3.3v from 5v, you need a regulator
(note that regulators need external capacitors if you're working with a bare regulator as opposed to a breakout board with one mounted on it with supporting parts - always read the datasheet of regulator for specs on the type and value of caps needed - regulators are often picky about not just capacitor values but the type of capacitor as well)
You can't use a resistor unless the load is constant (like an LED or a lightbulb, and unlike a webcam), because the voltage drop depends on current, and using a stack of diodes to drop voltage isn't ideal either, as the voltage drop will still depend on current, just not as strongly.
For data/signal, as opposed to power, that's called "level shifting" and you can buy level shifter boards from china for practically nothing.
Thanks
RaveloGlennorKhris:
Regulator regulates the output voltage, resistors or diodes will not.
You can shunt regulate using a zener and resistor, but that's less efficient and very soft regulation
compared to a linear regulator designed for the task.
Most linear regulators shutdown on over current or over temperature, so handle fault conditions like output
short-circuit, resistors/diodes will burn out and take your circuit with them!
RaveloGlennorKhris:
Best option for your application is a linear regulator. It will regulate the voltage to 3.3V, for a range of input voltage. (Ex. LM1117-3.3V linear dropout regulator) you may need two tantalum capacitors to get the best out of it.
If supply voltage is fixed, you can use diodes too.
Resistors will work fine only for linear resistive loads. And may need in higher wattage to cater the demand. My opinion is, it is not suitable for your application.
There is another option to use a buck converter. However it will be expensive, and will be complex to make it with no noises.
Thanks to all
