Resistors
How would I figure out the resistor I would need for this? :
Could you give us a datasheet? A part number, even just a brand?
Product Features
Run with single IO using Virtuabotix Exclusive Library!
This Ultrasonic Sensor instantly detect obstacles with the microcontroller of your choice!
Free Arduino library & Other resources available from Virtuabotix!
Comes fully tested and sealed in retail ready package.
Static current: Less than 2mA. High precision: Up to 0.3cm Sensor angle: 15 degrees. Detection distance: 2cm-500cm.
by Virtuabotix
How would I figure it out?
Why do you think you need a resistor and where are you proposing to put it?
Yeah I don't think you need a resistor for that.
This is not the Virtuabotix forum.
Ask there, if you cannot find information, but search first, please, and don't tell them I sent you :wink:
That module, from what I can see searching around, has a trigger input and echo output, both logic signals so no resistor is needed. Arduino Forum
