(RESOLU) Compilation Error : Exit status 1
Bonjour j'ai un problème avec arduino voici mon code
#include <Modulino.h>
#include <Arduino_LED_Matrix.h>
ModulinoBuzzer buzzer;
ModulinoButtons buttons;
ModulinoPixels leds;
ArduinoLEDMatrix matrix;
ModulinoColor OFF(0, 0, 0);
int ledPosition = 0;
bool movingUp = true;
unsigned long previousMillis = 0;
long interval = 100;
const long intervalDecrement = 5;
const long minInterval = 50;
int targetPosition;
bool gameActive = true;
  Modulino.begin();
  buzzer.begin();
  buttons.begin();
  leds.begin();
  matrix.begin();
  randomSeed(analogRead(A0));
  matrix.loadFrame(LEDMATRIX_EMOJI_BASIC);
  startNewGame();
  if (gameActive) {
    if (currentMillis - previousMillis >= interval) {
      leds.set(ledPosition, OFF, 4);
      if (movingUp) {
        ledPosition++;
        if (ledPosition >= 7) {
          movingUp = false;
        ledPosition--;
        if (ledPosition <= 0) {
          movingUp = true;
      if (ledPosition == targetPosition) {
        leds.set(ledPosition, VIOLET, 4);
        leds.set(ledPosition, BLUE, 4);
        leds.set(targetPosition, RED, 4);
      leds.show();
    if (buttons.update() && (buttons.isPressed(0) || buttons.isPressed(1) || buttons.isPressed(2))) {
        win();
        lose();
void startNewGame() {
  gameActive = true;
  ledPosition = 0;
  movingUp = true;
  targetPosition = random(0, 8);
  for (int i = 0; i < 8; i++) {
    if (i == targetPosition) {
      leds.set(i, RED, 4);
      leds.set(i, OFF, 4);
  leds.show();
void win() {
  gameActive = false;
  matrix.loadFrame(LEDMATRIX_EMOJI_HAPPY);
  buzzer.tone(1000, 500);
  leds.set(targetPosition, GREEN, 4);
  leds.show();
  Serial.println("You Win!");
  if (interval > minInterval) {
    interval -= intervalDecrement;
  startNewGame();
void lose() {
  gameActive = false;
  matrix.loadFrame(LEDMATRIX_EMOJI_SAD);
  buzzer.tone(200, 500);
  Serial.println("You Lose!");
  interval = 100;
  startNewGame();
quand je compile Arduino IDE écrit ça :
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2
Using core 'arduino' from platform in folder: /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2
Detecting libraries used...
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Modulino.h: [Modulino@0.4.2]
ResolveLibrary(Modulino.h)
  -> candidates: [Modulino@0.4.2]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Wire.h: [Wire]
ResolveLibrary(Wire.h)
  -> candidates: [Wire]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour vl53l4cd_class.h: [STM32duino VL53L4CD@1.0.5]
ResolveLibrary(vl53l4cd_class.h)
  -> candidates: [STM32duino VL53L4CD@1.0.5]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour vl53l4ed_class.h: [STM32duino VL53L4ED@1.0.1]
ResolveLibrary(vl53l4ed_class.h)
  -> candidates: [STM32duino VL53L4ED@1.0.1]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Arduino_LSM6DSOX.h: [Arduino_LSM6DSOX@1.1.2]
ResolveLibrary(Arduino_LSM6DSOX.h)
  -> candidates: [Arduino_LSM6DSOX@1.1.2]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour SPI.h: [SPI@1.0 SPI]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0 SPI]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Arduino_LPS22HB.h: [Arduino_LPS22HB@1.0.2]
ResolveLibrary(Arduino_LPS22HB.h)
  -> candidates: [Arduino_LPS22HB@1.0.2]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Arduino_HS300x.h: [Arduino_HS300x@1.0.0]
ResolveLibrary(Arduino_HS300x.h)
  -> candidates: [Arduino_HS300x@1.0.0]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
Alternative pour Arduino_LED_Matrix.h: [LED_Matrix@1.1.0]
ResolveLibrary(Arduino_LED_Matrix.h)
  -> candidates: [LED_Matrix@1.1.0]
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire/Wire.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src/platform.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src/vl53l4cd_api.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src/vl53l4cd_calibration.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src/platform.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src/vl53l4ed_api.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src/vl53l4ed_calibration.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/LSM6DSOX.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/SPI/SPI.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src/BARO.cpp -o /dev/null
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src/HS300x.cpp -o /dev/null
Generating function prototypes...
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/159210649/sketch_merged.cpp
/Users/aq/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/159210649/sketch_merged.cpp
Compilation du croquis...
/Users/aq/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -Wall -Wextra -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch_jan4a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/Users/aq/Documents/Arduino/libraries/Modulino/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD/src -I/Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED/src -I/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src -I/Users/aq/Documents/Arduino/libraries/SPI -I/Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB/src -I/Users/aq/Documents/Arduino/libraries/Arduino_HS300x/src -I/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix/src -iprefix/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2 @/Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp -o /Users/aq/Library/Caches/arduino/sketches/A7D8AE0572C71BA0E45DF077D4EBEEA4/sketch/sketch_jan4a.ino.cpp.o
In file included from /Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/LSM6DSOX.h:22:0,
                 from /Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/Arduino_LSM6DSOX.h:23,
                 from /Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:7,
                 from /private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/.arduinoIDE-unsaved202504-7552-92vh72.bbe8b/sketch_jan4a/sketch_jan4a.ino:25:
/Users/aq/Documents/Arduino/libraries/SPI/SPI.h:1439:8: error: 'SPIClass' does not name a type; did you mean 'DhcpClass'?
 extern SPIClass SPI;
        DhcpClass
In file included from /Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/Arduino_LSM6DSOX.h:23:0,
/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/LSM6DSOX.h:27:27: error: expected ')' before '&' token
     LSM6DSOXClass(SPIClass& spi, int csPin, int irqPin);
/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/LSM6DSOX.h:56:5: error: 'SPIClass' does not name a type; did you mean 'DhcpClass'?
     SPIClass* _spi;
     DhcpClass
/Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX/src/LSM6DSOX.h:61:5: error: 'SPISettings' does not name a type
     SPISettings _spiSettings;
In file included from /private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/.arduinoIDE-unsaved202504-7552-92vh72.bbe8b/sketch_jan4a/sketch_jan4a.ino:25:0:
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:49:47: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
   Module(uint8_t address = 0xFF, char* name = "")
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In constructor 'ModulinoButtons::ModulinoButtons(uint8_t)':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:122:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     : Module(address, "BUTTONS") {}
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In member function 'virtual uint8_t ModulinoButtons::discover()':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:144:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     for (int i = 0; i < sizeof(match)/sizeof(match[0]); i++) {
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In constructor 'ModulinoBuzzer::ModulinoBuzzer(uint8_t)':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:160:31: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     : Module(address, "BUZZER") {}
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In member function 'virtual uint8_t ModulinoBuzzer::discover()':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:173:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In constructor 'ModulinoPixels::ModulinoPixels(uint8_t)':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:198:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     : Module(address, "LEDS") {
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In member function 'virtual uint8_t ModulinoPixels::discover()':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:220:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In constructor 'ModulinoKnob::ModulinoKnob(uint8_t)':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:238:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     : Module(address, "ENCODER") {}
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In member function 'virtual uint8_t ModulinoKnob::discover()':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:277:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h: In member function 'bool ModulinoDistance::available()':
/Users/aq/Documents/Arduino/libraries/Modulino/src/Modulino.h:483:11: warning: unused variable 'ret' [-Wunused-variable]
     float ret = internal;
/private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/.arduinoIDE-unsaved202504-7552-92vh72.bbe8b/sketch_jan4a/sketch_jan4a.ino: In function 'void loop()':
/private/var/folders/vr/z1q31xx97ld61mzmvnr3k8zw0000gn/T/.arduinoIDE-unsaved202504-7552-92vh72.bbe8b/sketch_jan4a/sketch_jan4a.ino:67:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Plusieurs bibliothèque trouvées pour "SPI.h"
  Utilisé: /Users/aq/Documents/Arduino/libraries/SPI
  Non utilisé: /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SPI
Utilisation de la bibliothèque Modulino version 0.4.2 dans le dossier: /Users/aq/Documents/Arduino/libraries/Modulino
Utilisation de la bibliothèque Wire prise dans le dossier: /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Wire (héritage)
Utilisation de la bibliothèque STM32duino VL53L4CD version 1.0.5 dans le dossier: /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4CD
Utilisation de la bibliothèque STM32duino VL53L4ED version 1.0.1 dans le dossier: /Users/aq/Documents/Arduino/libraries/STM32duino_VL53L4ED
Utilisation de la bibliothèque Arduino_LSM6DSOX version 1.1.2 dans le dossier: /Users/aq/Documents/Arduino/libraries/Arduino_LSM6DSOX
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: /Users/aq/Documents/Arduino/libraries/SPI
Utilisation de la bibliothèque Arduino_LPS22HB version 1.0.2 dans le dossier: /Users/aq/Documents/Arduino/libraries/Arduino_LPS22HB
Utilisation de la bibliothèque Arduino_HS300x version 1.0.0 dans le dossier: /Users/aq/Documents/Arduino/libraries/Arduino_HS300x
Utilisation de la bibliothèque LED_Matrix version 1.1.0 dans le dossier: /Users/aq/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.3.2/libraries/Arduino_LED_Matrix
exit status 1
Compilation error: exit status 1
J'utilise Arduino IDE 2.3.4 sur un MacOS 10.15 .
Pouvez vous m'aider s'il-vous-plait ?
:warning:
Post mis dans la mauvaise section, on parle anglais dans les forums généraux. déplacé vers le forum francophone.
Merci de prendre en compte les recommandations listées dans Les bonnes pratiques du Forum Francophone
Je ne suis pas loin de penser que le problème se situe ici
La librairie utilisée est la librairie SPI standard alors qu'il faudrait utiliser celle qui se trouve dans le package renesas.
Il faudrait essayer de supprimer temporairement la librairie SPI dans libraries pour voir si cela résout le problème. Ce n'est pas très élégant mais cela permettra de confirmer le problème. Ou bien mettre le chemin complet vers la librairie dans l'include.
Merci beaucoup ça a marché ! :smiley: :+1:
