Bonjour, j'ai un petit soucis avec ce code:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
Gestion Carte 4 Relais
avec un serveur Web Arduino
Materiel:
* Arduino UNO
* Arduino Ethernet shield
* Carte 4 Relais
byte mac[] = { xxxx, xxxx, xxxx, xxxx, xxxx, xxxx }; //Adresse MAC
byte ip[] = { 192, 168, x, xx }; // Adresse IP
EthernetServer server(xx); //Port du serveur
int ledPin1 = 3; // LED pin
int ledPin2 = 2; // LED pin
int ledPin3 = 5; // LED pin
String readString = String(30); //string for fetching data from address
boolean LEDON1 = false; //Pin status flag
boolean LEDON2 = false; //Pin status flag
boolean LEDON3 = false; //Pin status flag
void setup(){
//start Ethernet
Ethernet.begin(mac, ip);
//Configurer les 3 Pins de sorties
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
//Activer la liaison de données Serie
Serial.begin(9600); }
void loop(){
//Créer la connection Client
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30) {
//store characters to string
readString += c; }
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//lets check if LED should be lighted
//Controle Prise 1
if(readString.indexOf("L=1")>0) {
//Pin mise a ON
digitalWrite(ledPin1, LOW); // Mettre la Pin a ON
LEDON1 = true;
}else if(readString.indexOf("L=1")<0){
//Pin mise a OFF
digitalWrite(ledPin1, HIGH); /// Mettre la Pin a OFF
LEDON1 = false; }
//Controle Prise 2
if(readString.indexOf("L1=2")>0) {
//Pin mise a ON
digitalWrite(ledPin2, LOW); // Mettre la Pin a ON
LEDON2 = true;
}else if(readString.indexOf("L1=2")<0){
//Pin mise a OFF
digitalWrite(ledPin2, HIGH); // Mettre la Pin a OFF
LEDON2 = false; }
//Controle Prise 3
if(readString.indexOf("L2=3")>0) {
//Pin mise a ON
digitalWrite(ledPin3, LOW); // Mettre la Pin a ON
LEDON3 = true;
}else if(readString.indexOf("L2=3")<0){
//Pin mise a OFF
digitalWrite(ledPin3, HIGH); // Mettre la Pin a OFF
LEDON3 = false; }
// now output HTML data starting with standart header
client.println("HTTP/1.0 200 OK");
client.println("Content-Type: text/html");
client.println();
//Controle Relais par checkbox
client.println("<h1>Gestion des prises</h1>");
client.println("<form method=get name=Prise><input type=CHECKBOX name=L value=1>Prise 1
client.println("
client.println("<input type=CHECKBOX name=L1 value=2>Prise 2
client.println("
client.println("<input type=CHECKBOX name=L2 value=3>Prise 3
<input type=submit value=submit></form>");
client.println("
//Afficher statut prise 1
client.print("Prise1: ");
if (LEDON1)
client.println("ON
client.println("OFF
client.println("</body></html>");
//Afficher statut prise 2
client.print("Prise2: ");
if (LEDON2)
client.println("ON
client.println("OFF
//Afficher statut prise 3
client.print("Prise3: ");
if (LEDON3)
client.println("ON
client.println("OFF
//Effacer la chaine pour lecture suivante
readString="";
//Arreter le client
client.stop();
Quand je le fais tourner avec IE ça fonctionne, mais quand je le fais tourner avec Chrome, cela ne fonctionne pas.
Chrome me demande le favicon.ico, ce qui fait bugger le programme et ne me met pas mes sorties dans le bon état.
Les conditions If sont scratchées et du coup le programme ne fait pas ce que je lui demande.
J'ai essayé de rajouter cette condition qui normalement doit fonctionner:
//dirty skip of "GET /favicon.ico HTTP/1.1"
if (readString.indexOf("?") <0)
//skip everything
Ce qui donne un code final :
#include <SPI.h>
Materiel:
* Arduino UNO
* Carte 4 Relais
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xB5, 0x42 }; //Adresse MAC
byte ip[] = { 192, 168, 1, 12 }; // Adresse IP
EthernetServer server(80); //Port du serveur
void setup(){
//start Ethernet
void loop(){
if (client) {
readString += c; }
Serial.print(c);
if (c == '\n') {
//skip everything
//Controle Prise 1
//Pin mise a ON
LEDON1 = true;
//Pin mise a OFF
LEDON1 = false; }
//Controle Prise 2
//Pin mise a ON
LEDON2 = true;
//Pin mise a OFF
LEDON2 = false; }
//Controle Prise 3
//Pin mise a ON
LEDON3 = true;
//Pin mise a OFF
LEDON3 = false; }
client.println();
client.println("
client.println("
client.println("
if (LEDON1)
client.println("ON
client.println("OFF
if (LEDON2)
client.println("ON
client.println("OFF
if (LEDON3)
client.println("ON
client.println("OFF
readString="";
//Arreter le client
client.stop();
Mais j'ai toujours le même problème...
Le code que je souhaite faire marché est en fait issu de ce site:
http://can59-3-82-233-175-232.fbx.proxad.net/~aurelien/drupal7/?q=node/28
