[RESOLU] Impossible de "verrouiller" Projet 12 Starter Kit
Bonsoir à tous,
J’ai un petit soucis sur le projet 12 du Starter Kit, Knock Lock. En effet lorsque je fais les 3 tocs la led verte s’allume et le servo pivote de 90°. Jusqu’ici pas de soucis. Mais lorsque je clique sur le bouton poussoir pour verrouiller, le servo pivote dans l’autre sens mais revient directement en position ouvert. Idem pour la led rouge, elle s’allume et puis s’éteint et la verte se rallume.
#include <Servo.h>
Servo myServo;
const int piezo = A0;      // pin the piezo is attached to
const int switchPin = 2;    // pin the switch is attached to
const int yellowLed = 3;    // pin the yellow LED is attached to
const int greenLed = 4;    // pin the green LED is attached to
const int redLed = 5;   // pin the red LED is attached to
int knockVal;
int switchVal;
const int quietKnock = 20;
const int loudKnock = 100;
boolean locked = false;
int numberOfKnocks = 0;
void setup(){
  myServo.attach(9);
  pinMode(yellowLed, OUTPUT);
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(switchPin, INPUT);
  digitalWrite(greenLed, HIGH);
  myServo.write(0);
  Serial.println("the box is unlocked!");
void loop(){
  if(locked == false){
    switchVal = digitalRead(switchPin);
    if(switchVal == HIGH){
      locked = true;
      digitalWrite(greenLed,LOW);
      digitalWrite(redLed,HIGH);
      myServo.write(90);
      Serial.println("the box is locked!");
      delay (1000);
  if(locked == true){
    knockVal = analogRead(piezo);
    if(numberOfKnocks < 3 && knockVal > 0){
      if(checkForKnock(knockVal) == true){
        numberOfKnocks++;
      Serial.print(3 - numberOfKnocks);
      Serial.println(" more knocks to go");
    if(numberOfKnocks >= 3){
      locked = false;
      myServo.write(0);
      delay(20);
      digitalWrite(greenLed,HIGH);
      digitalWrite(redLed,LOW);
boolean checkForKnock(int value){
  if(value > quietKnock && value < loudKnock){
    digitalWrite(yellowLed, HIGH);
    delay(50);
    digitalWrite(yellowLed, LOW);
    Serial.print("Valid knock of value ");
    Serial.println(value);
    return true;
  else {
    Serial.print("Bad knock value ");
    return false;
Je vous remercie d’avance pour votre aide
J’ai trouvé il manquait une ligne dans le code donné dans le livre… Rien ne disait à l’Arduino de fermer si il ne recevait pas de “Knocks”.
Pour ceux qui auront le même problème voici le code corrigé :wink:
#include <Servo.h>
Servo myServo;
int knockVal;
int switchVal;
void setup(){
  myServo.attach(9);
  myServo.write(0);
void loop(){
      locked = true;
      myServo.write(90);
      delay (1000);
  if(locked == true){
        numberOfKnocks++;
      locked = false;
      myServo.write(0);
      delay(20);
      numberOfKnocks = 0; //correction
    delay(50);
    return true;
  else {
    return false;
