[résolu] SD nom de fichier et RTC
hello Arduiners,
Je viens vers vous car j’ai un souci que je ne comprend pas, je m’explique.
mon projet est d’écrire dans un fichier l’heure et avec du texte à la suite et de répeter tous ca tous les 20sec.
De plus je souhaite créer un fichier pour chaque jour.
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
#include <SPI.h>
#include <SD.h>
#include <string.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
#include <Wire.h>
#include "RTClib.h"
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
int jour;
int mois;
int annee;
int heure;
int minutes;
int secondes;
char car_secondes [2]="";
char car_minutes [2]="";
char car_jours [2]="";
char car_mois [2]="";
boolean flagwrite=0;
RTC_DS1307 RTC;  // Variable RTC permettant de lire la date
String dataString = "";
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
	Serial.println("RTC is NOT running!");
	// following line sets the RTC to the date & time this sketch was compiled
	RTC.adjust(DateTime(__DATE__, __TIME__));
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  digitalWrite(10,HIGH);
  pinMode(53, OUTPUT);
  digitalWrite(53,HIGH);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  DateTime now = RTC.now();
  annee= now.year()%100,DEC;
  car_mois[0]=now.month()/10,DEC;
  car_mois[1]=now.month()%10,DEC;
  car_jours[0]=now.day()/10,DEC;
  car_jours[1]=now.day()%10,DEC;
  heure=now.hour(),DEC;
  car_minutes[0]=now.minute()/10,DEC;
  car_minutes[1]=now.minute()%10,DEC;
  secondes=now.second(),DEC;
  car_secondes[0]=now.second()/10,DEC;
  car_secondes[1]=now.second()%10,DEC;
Serial.print(secondes);
Serial.print("\n");
Serial.print(minutes);
Serial.print("\n");
Serial.print(heure);
Serial.print("\n");
Serial.print(jour);
Serial.print("\n");
	  Write_SD();
	  delay(2000);
La partie du code en haut marche correctement j’ai bien l’heure affiché. La carte est bien initialisé et reconnu ensuite j’appelle la fonction writeSD que voici, dans cette fonction j’ai crée une variable filename qui prend la date du jour au format 11-04-14.txt
ensuite dans une variable datastring j’écrit le texte que j’ai besoin.
void Write_SD ()
	char temp[8]="";
	char namefile[12] ="";
	sprintf(namefile,"%d%d-%d%d-%d",car_jours[0],car_jours[1],car_mois[0],car_mois[1],annee);//%d%d-%d%d-car_jours[0],car_jours[1],car_mois[0],car_mois[1]
	Serial.print(namefile);
	Serial.print("\n");
	sprintf(temp,"%d:%d%d:%d%d",heure,car_minutes[0],car_minutes[1],car_secondes[0],car_secondes[1]);
	Serial.print(temp);
	Serial.print("\n");
	// make a string for assembling the data to log:
	dataString ="";
	// Construction de la ligne a écrire
	dataString = "String(temp)";
	dataString += "	";//une tabulation
	//Serial.println(dataString);
	dataString += "String(LNA1)";
	//	Serial.println(LNA1);
	dataString += "String(LNA2";
	//	Serial.println(dataString);
	// open the file. note that only one file can be open at a time, Regarder ICI si on a changé de jour si oui créer un nouveau fichier.
	// so you have to close this one before opening another.
	File dataFile = SD.open(namefile , FILE_WRITE);
	if (SD.exists(namefile)) {
		Serial.println("its exists.");
		// if the file is available, write to it:
		if (dataFile)
			dataFile.println(dataString);
			dataFile.close();
			// print to the serial port too:
			//logfile_flag = LOW; //Efface le flag d'error
			flagwrite=1;
		// if the file isn't open, pop up an error:
		Serial.println("doesn't exist.");
		Serial.println("error opening .txt");
		//logfile_flag = HIGH; //error
	dataString ="";
Le point que je ne comprend pas c’est que le filename est bien écrit il contient 8.3 caractere en format date 11-04-14.txt
mais le fichier ne se crée pas.
J’ai donc tester de remplacer cette ligne
par celle ci
File dataFile = SD.open("11-05-14.txt", FILE_WRITE);
	if (SD.exists("11-05-14.txt")) {
Et la ça marche le fichier :stuck_out_tongue_closed_eyes: se crée et les lignes s’incrémente correctement en fonction du temps.
Le point est que je ne comprend pas pourquoi le fichier ne se crée pas avec la variable.
Si quelqu’un a une idée de piste a suivre je suis preneur.
En vous remerciant.
Maxime
J'ai l'impression qu'il manque ".txt" à ta variable namefile non?
Que donne le Serial.print(namefile); ?
Oups, oui il manque le .txt voila le code
char temp[9]="00-00-00";
    char namefile[13] ="00-00-00.txt";
    sprintf(namefile,"%d%d-%d%d-%d.txt",car_jours[0],car_jours[1],car_mois[0],car_mois[1],annee);//%d%d-%d%d-car_jours[0],car_jours[1],car_mois[0],car_mois[1]
    Serial.print("\n");
    Serial.print(temp);
    Serial.print("\n");
J'ai pas trouvé le probléme en tout cas je l'ai corrigé en initialisant mes variables namefile et temp comme au dessus. Le truc que je comprend pas est que le namefile contient au maximum 12 caracteres mais lorsque je compilais cette sequence char namefile[12] ="00-00-00.txt"; il me mettait une erreur comme quoi mon initialisation était trop longue pour mon tableau. J'ai donc ajouté plus 1 à mon tableau et la miracle ca s'exécute et j'ai bien mon fichier de créer avec le texte dedans. Je vais le laisser tourner tout ce weekend et on verra bien demain si ca a créer un nouveau fichier. Merci John d'être venu à ma rescousse. j'ai pas compris pourquoi ça marchait mais ça marche si quelqu'un comprend je suis toujours preneur. Maxime
Relis le principe de création d'un tableau de char et du caractère de fin de chaine '\0' et tu comprendras pourquoi il faut créer un tableau à [13] à la place de [12]
Ce n'est pas un
miracle
Il y a 12 caractères de nom de fichier (8.3) auxquels on doit ajouter un code de fin de chaîne '\0', (invisible) ça fait 13 emplacement en mémoire à réserver.
Merci pour l'information.
