bricofoy:
je ne vois pas en quoi ce serait incompatible ?
il suffit de remplacer rtclib.h par timelib.h et d'adapter la fonction qui lit le ntp
voilà le code de l'exemple en question, la librairie est installable directement depuis le gestionnaire :
- Time_NTP.pde
- Example showing time sync to NTP time source
- This sketch uses the Ethernet library
#include <TimeLib.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// NTP Servers:
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov
const int timeZone = 1; // Central European Time
//const int timeZone = -5; // Eastern Standard Time (USA)
//const int timeZone = -4; // Eastern Daylight Time (USA)
//const int timeZone = -8; // Pacific Standard Time (USA)
//const int timeZone = -7; // Pacific Daylight Time (USA)
EthernetUDP Udp;
unsigned int localPort = 8888; // local port to listen for UDP packets
while (!Serial) ; // Needed for Leonardo only
delay(250);
Serial.println("TimeNTP Example");
if (Ethernet.begin(mac) == 0) {
// no point in carrying on, so do nothing forevermore:
while (1) {
Serial.println("Failed to configure Ethernet using DHCP");
delay(10000);
Serial.print("IP number assigned by DHCP is ");
Serial.println(Ethernet.localIP());
Udp.begin(localPort);
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
time_t prevDisplay = 0; // when the digital clock was displayed
if (timeStatus() != timeNotSet) {
if (now() != prevDisplay) { //update the display only if time has changed
prevDisplay = now();
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
/-------- NTP code ----------/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.println("Transmit NTP Request");
sendNTPpacket(timeServer);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
int size = Udp.parsePacket();
if (size >= NTP_PACKET_SIZE) {
Serial.println("Receive NTP Response");
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
unsigned long secsSince1900;
// convert four bytes starting at location 40 to a long integer
secsSince1900 = (unsigned long)packetBuffer[40] << 24;
secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
secsSince1900 |= (unsigned long)packetBuffer[43];
return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response :-(");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
ca ne marche pas , j ' ai juste ajouté les libs manquantes et quand je tente la compilation :
home/iznobe/Arduino/SKETCH/serveur volets/serveur_volet_arrosage_RTC.v6.21/serveur_volet_arrosage_RTC.v6.21.ino:829:105: warning: invalid conversion from 'void (*)(byte, long unsigned int) {aka void (*)(unsigned char, long unsigned int)}' to 't_callback {aka void (*)(unsigned int)}' [-fpermissive]
gestionnaireDeTache.registerAsyncCommand( numRelais, CalculEspaceJoursArrosage(zone) , MarcheArrosage ); // tourne en boucle
In file included from /home/iznobe/Arduino/SKETCH/serveur volets/serveur_volet_arrosage_RTC.v6.21/serveur_volet_arrosage_RTC.v6.21.ino:3:0:
/home/iznobe/Arduino/libraries/AsyncTask/AsyncTask.h:35:10: note: initializing argument 3 of 'bool AsyncTask<queueLength>::registerAsyncCommand(t_commandID, uint32_t, t_callback) [with unsigned int queueLength = 10; t_commandID = unsigned int; uint32_t = long unsigned int; t_callback = void (*)(unsigned int)]'
bool registerAsyncCommand(t_commandID id, uint32_t deltaT, t_callback cb) {
Plusieurs bibliothèque trouvées pour "Ethernet.h"
Utilisé : /home/iznobe/Arduino/libraries/Ethernet
Non utilisé : /home/iznobe/arduino-1.8.12/libraries/Ethernet
Plusieurs bibliothèque trouvées pour "RTClib.h"
Utilisé : /home/iznobe/Arduino/libraries/RTClib
Non utilisé : /home/iznobe/Arduino/libraries/RTCLib_by_NeiroN
Non utilisé : /home/iznobe/Arduino/libraries/arduino_576780
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: /home/iznobe/arduino-1.8.12/hardware/arduino/avr/libraries/SPI
Utilisation de la bibliothèque Ethernet2-master version 1.0.4 dans le dossier: /home/iznobe/Arduino/libraries/Ethernet2-master
Utilisation de la bibliothèque AsyncTask prise dans le dossier : /home/iznobe/Arduino/libraries/AsyncTask (legacy)
Utilisation de la bibliothèque RTClib version 1.4.0 dans le dossier: /home/iznobe/Arduino/libraries/RTClib
Utilisation de la bibliothèque Time version 1.6 dans le dossier: /home/iznobe/Arduino/libraries/Time
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: /home/iznobe/arduino-1.8.12/hardware/arduino/avr/libraries/Wire
Utilisation de la bibliothèque DS1307RTC version 1.4.1 dans le dossier: /home/iznobe/Arduino/libraries/DS1307RTC
Utilisation de la bibliothèque Ethernet version 2.0.0 dans le dossier: /home/iznobe/Arduino/libraries/Ethernet
exit status 1
Erreur de compilation pour la carte Arduino Mega or Mega 2560
les lib ethernet et ethernet2 n ' ont jamais ete compatible , pour la lib EthernetUdp et EthernetUdp2 , je ne sais pas , mais je sais que je n' ai pas pu installer l ' udp classique , il fallait celle que j ' ai mis avec Ethernet2 .
faite un essai avec ce simple fichier :
#include <Ethernet2.h>
