Looking to integrate the following micro-stepper controller with an arduino 328 / arduino mega:
Critical Velocity : 2.5 Amp Microstepping Bipolar Stepper Motor Driver from critical velocity
Should the input ST & DIR from the Arduino be isolated with a resistor to prevent kickback from the stepper coils?
Anyone have any ideas on how to wire this up as its not the std motorshield I have 2 4 wire bipolar steppers that I would like to test as they have significantly difftorque output and Id rather use the smaller if possible.
Should be a pretty simple setup. The digital inputs to the controller, step and direction are optically isolated so no protection diodes will be needed. Just wire the step and direction signals to two Arduino digital output pins and wire the Arduino ground pin to the isoground shown on the very first connection drawing shown in the data manual. Also that very first wiring example shows a 4 wire stepper connection.
Thank for chiming in. I wired up the controller with a 12V 1.25A Ac Adapter, connected a M42sp-13NK (printer salvage) to the driver after reading the paired wires resistance at 4.7Ohms and finally to the arduino via pin 7 for DIR and pin 9 for STEP.
Is there any holding force on the motor when it's all power up compared to when it's not powered up? I can't see any wrong with your hook up. Is there a motor voltage rating on the motor lable?
This would be the time I would break out the scope and meter and check for signals on the input and voltages and current values.
There is also a current adjust pot somewhere on the controller.
Motor Current Adjustment:
Use the motor current potentiometer to adjust the current level to suit the motor. Do not exceed the
motor's current rating to prevent overheating. The full scale of the current adjust potentiometer is from
2.5A down to 0.25A at the rightmost position. "
Ok I am a chimp.... after working a 14 hour day and coming home to do this project I read the PSU on the meter and reversed the polarity to the controller after I was done.... everything workds wonderfully and I now am going to facepalm myself LOL
Thanks for your help Lefty
BTW controller works amazingly.... 1/8th step resolution is awesome!
