Hi I am building a USB MIDI controller and have nearly finished my project when suddenly my Leonardo has stopped uploading. This is very frustrating considering the time I took for this project and changing the board would be a real problem.
The board is recognised and still transmitting on serial port when I connect it, with potentiometers and button working fine (only my trellis LEDs turn on in a weird way when I turn the controller on) but I can no longer upload any sketch.
I have pasted the error message:
Archiving built core (caching) in: E:\Users\WEB\AppData\Local\Temp\arduino_cache_79589\core\core_arduino_avr_leonardo_de2016e466ce3eaab2c66f7991bbc0b4.a
Sketch uses 5088 bytes (17%) of program storage space. Maximum is 28672 bytes.
Global variables use 457 bytes (17%) of dynamic memory, leaving 2103 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM10
PORTS {COM1, COM10, } / {COM1, COM10, } => {}
PORTS {COM1, COM10, } / {COM1, } => {}
PORTS {COM1, } / {COM1, COM10, } => {COM10, }
Found upload port: COM10
E:\Users\WEB\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CE:\Users\WEB\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM10 -b57600 -D -Uflash:w:E:\Users\WEB\AppData\Local\Temp\arduino_build_470710/MIDIUSB_read.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\Users\WEB\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM10
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
I have disconnected all midi programs that could interfere with with the Leonardo (midi Ox, bome midi translator, previously the have interfered at times when uploading), rebooted computer and reset the board but nothing works... I have connected an arduino UNO just to test another board and that works fine but communication with the leonardo is gone....!!
Could it be the bootloader? (I don't know a lot about it)
I have also noticed that on my windows port list the device is seen as "Teensy" (I used a Teensy for a previous project).
I wander whether this may also be the result of following the direction in this website: (MIDI device with a name of your choice) to change the device name. However, after changing the name it had been working OK for days, until today...
Another possible reason could be that I corrupted the bootloader. My code involved writhing char arrays in progmen...
Any advice ?
:o :o
