[Resolved] Array must be initialized with a brace-enclosed initializer
static inline uint16_t Color_To_565(uint8_t r, uint8_t g, uint8_t b){
  return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | ((b & 0xF8) >> 3);
typedef struct{
  char text[12];
  uint16_t color;
}Button;
static const char ref[] PROGMEM = "References";
static const char ren[] PROGMEM = "Rename";
static const char gs[] PROGMEM = "Get/Set...";
static const char nc[] PROGMEM = "New Class";
static const char exm[] PROGMEM = "Ext. Meth.";
static const char tstr[] PROGMEM = "ToString...";
static const char inl[] PROGMEM = "InLine";
static const char rtst[] PROGMEM = "Runt Test";
static const char none[] PROGMEM = "?";
#define BUT_REF       { ref,   Color_To_565(255, 190, 98 ) }
#define BUT_REN       { ren,   Color_To_565(255, 190, 98 ) }
#define BUT_GETSET    { gs,    Color_To_565(64 , 219, 187) }
#define BUT_NEWCLASS  { nc,    Color_To_565(64 , 219, 187) }
#define BUT_EXTMETH   { exm,   Color_To_565(106, 175, 255) }
#define BUT_TOSTR     { tstr,  Color_To_565(64 , 219, 187) }
#define BUT_INLINE    { inl,   Color_To_565(106, 175, 255) }
#define BUT_RUNTEST   { rtst,  Color_To_565(255, 104, 129) }
#define BUT_NONE      { none,  0x0000                      }
#define BUTS  { BUT_REF, BUT_REN, BUT_GETSET, BUT_NEWCLASS, BUT_EXTMETH },{ BUT_TOSTR, BUT_INLINE, BUT_RUNTEST, BUT_NONE, BUT_NONE }
static const Button buttons[NB_COL][NB_ROW] PROGMEM = { BUTS };
This gives me:
‘array must be initialized with a brace-enclosed initializer’
on the
I don’t understand why ?!
I think Color_To_565() is not a constant (even though it's an inline function), so it can't be used to initialize a global static variable. Try defining it as another macro, instead.
Is the code you posted the same as you are trying to compile, I get a completely different error, which is caused by Button.text being declared as a char array instead of a const char*
#define Color_To_565(r,g,b) ((((r) & 0xF8) << 8) | (((g) & 0xFC) << 3) | (((b) & 0xF8) >> 3))
typedef struct{
  char* text;
  uint16_t color;
}Button;
#define NB_COL 2
#define NB_ROW 5
I’ve corrected:
typedef struct{
  const char text[12];
  uint16_t color;
}Button;
After some tests, i’ve found that it’s the line
That seems to cause the problem.
I’ve finally replace the color function with hex value.
Created each button in a variable in PROGMEM (with direct String creation)
static const Button but_ref PROGMEM = { "References", 0xFDEC};
static const Button but_ren PROGMEM = { "Rename",   0xFDEC};
added these to the final array:
static const Button buttons[NB_COL][NB_ROW] PROGMEM =  { { but_ref,...},{but_ren,...}  } ;
It’s finally working.
Thanks.
There’s no need to use macros here, just make the Color_To_565 function constexpr. I also added a default constructor for your struct so you don’t have to repeat the “none” button initialization in the array.
constexpr uint16_t Color_To_565(uint8_t r, uint8_t g, uint8_t b){
struct Button {
  constexpr Button(const char *text, uint16_t color)
   : text(text), color(color) {}
  constexpr Button() : text(none), color(0x0000) {}
  const char *text;
  uint16_t color;
const Button buttons[][5] PROGMEM = {
    { ref,  Color_To_565(255, 190, 98 ) },
    { ren,  Color_To_565(255, 190, 98 ) },
    { gs,   Color_To_565(64 , 219, 187) },
    { nc,   Color_To_565(64 , 219, 187) },
    { exm,  Color_To_565(106, 175, 255) },
    { tstr, Color_To_565(64 , 219, 187) },
    { inl,  Color_To_565(106, 175, 255) },
    { rtst, Color_To_565(255, 104, 129) },
  while (!Serial);
  for (const auto &row : buttons) {
    for (const auto &button_P : row) {
      Button button; // button in RAM
      memcpy_P(&button, &button_P, sizeof(button)); // copy from Flash to RAM
      Serial.println(reinterpret_cast<const __FlashStringHelper *>(button.text));
void loop() {}
Pieter
