(RESOLVED) code for water sensing windshield wiper robot
hey yall im building a variable speed windshield wiper w the following components (also see attachments):
  • arduino uno
  • L298N h-bridge
  • 12V gear head motor
  • water level sensor
  • 2 limit switches (pins NO, NC, C)
  • 2 6.5V batteries
it worked relatively decently when we controlled the wiping/halting by time intervals (same setup but without limit switches) but the motor doesn't always turn the same amount & it gets uncalibrated.
original code:
const int in1 = 9;
const int in2 = 8;
const int waterSensor = A1;
const int travelTime = 355;
int waterValue;
int haltTime;
  pinMode(waterSensor, INPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
void clockwise() {
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  delay(travelTime);
void counterClockwise() {
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  delay(travelTime);
void halt() {
  delay(haltTime);
void wipe() {
  clockwise();
  counterClockwise();
  halt();
  waterValue = analogRead(waterSensor);
  Serial.print("Value: ");
  Serial.println(waterValue);
  if (waterValue < 20)
    halt();
  else {
    if (waterValue < 250)
      haltTime = 2000;
    else if (waterValue < 390)
      haltTime = 1000;
      haltTime = 0;
    Serial.print("Halt: ");
    Serial.println(haltTime);
    wipe();
we got a couple limit switches to put on the bottom of the windshield & when triggered, would change the motor direction, but we haven't been able to get the code to work right since we attached the limit switches. we're all very inexperienced coders, but i had a CS major friend write the original code and the draft below:
const int  switchL = 4;
const int  switchR = 7;
const int   in1 =  9;
const int   in2 =  8;
bool  switchLState = 0;
bool  switchRState = 0;
  pinMode(switchL, INPUT);
  pinMode(switchR, INPUT);
void clockwise() {
  digitalWrite(in2,HIGH);
void halt(int haltTime) {
  delay(haltTime);
bool getWaterValue() {
  int waterValue;
  if (waterValue < 20 )
    return false;
  else if (waterValue < 250)
    halt(1500);
    halt(1000);
    halt(500);
  return true;
  switchLState = digitalRead(switchL);
  switchRState  = digitalRead(switchR);
  if (switchLState = HIGH) {
    bool isWet = getWaterValue();
    if (isWet)
      clockwise();
  else if (switchRState = HIGH)
    counterClockwise();
(there was also a version of this code with SwitchL and SwitchR defined as const byte instead of const int, i don't really understand the difference though)
so now when i hook everything up nothing happens whatsoever and i have no idea what i'm doing :slight_smile: any input whatsoever would be greatly appreciated thank u
UPDATE: the negative terminal on our motor had broken from numerous novice soldering jobs, but we got a new one and eventually got the code working. schematics are still the same. if anyone ever needs it:
int waterValue;
const int   in1 =  9;
const int   in2 =  8;
const int period = 500;
unsigned long time_now = 0;
  counterClockwise();
void clockwise() {
  delay(haltTime);
bool getWaterValue(bool wasPaused) {
  if (!wasPaused) {
      return false;
    else if (waterValue < 290)
      halt(2000);
    else if (waterValue < 350)
      halt(1000);
      halt(0);
  else { //wiper was paused, will resume with no delay once waterValue > 20
      return false;
  return true;
void intervalReading() {
  bool isWet = getWaterValue(true);
  while (!isWet) {
  clockwise();
  if (switchRState == LOW) {
    counterClockwise();
  else if (switchLState == LOW) {
    bool isWet = getWaterValue(false);
    if (isWet)
      clockwise();
      intervalReading();
Look up the difference between = and ==
