Hi all,
Using ATMega329PAU. I am trying to use a rising pin state on D2 (Ard Pin 2, Interrupt Pin 0) to wake device. I am finding code below does not sleep when D2 is connected to ground throughout. Printing the digital read value and checking on a bench meter shows the pin state to be a constant 0.
Question relates to GoingToSleep funtion below. Can you think of any reason why the code doesn't sleep in the middle if the D2 pin state is 0?
I have tried CHANGE and RISING interrupt.
Thanks,
Ben.
#include <math.h>
#include <avr/sleep.h>
#define interruptPin 2
#include "Arduino.h"
#include <avr/power.h>
#include <avr/wdt.h>
volatile int f_wdt=1;
float vout = 0.0;
float vin = 0.0;
float RV1 = 100000.0; // resistance of R1 (100K)
float RV2 = 10000.0; // resistance of R2 (10K)
int value = 0;
int ThermistorPin = 0;
int Vo;
float R1 = 10000;
float logR2, R2, T, HT, CT;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
int identifier = 88;
double thePower, tempC = 0, tempP = 0;
int count = 0;
char buffer1[30], buffer2[30];
int volt = 99;
int Irms = 999;
int index;
char inchar;
String temp = "";
char pos[80];
byte start_with = 0;
byte end_with = 0;
byte CRC = 0;
int b;
float a,y=0;
String incomingByte = "";
unsigned int stringLength;
int started = 0;
int l1 = 0;
int l2Pin = 3;
int lPin = 2;
int s1Pin = 13;
int s2Pin = 12;
int s3Pin = 11;
int s4Pin = 10;
int rbPin = 9;
int pPin = 8;
int lrPin = 5;
int lgPin = 6;
int lbPin = 7;
byte SENSE = 6;
int valve = 0;
ISR(WDT_vect) { // watchdog interrupt service, executed when watchdog timed out
if(f_wdt == 0) {
f_wdt=1;
void enterSleep(void) // timed sleep func
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
// continue after sleep
sleep_disable();
power_all_enable(); // re-enable the peripherals.
void setupWatchDogTimer() { // setup the Watch Dog Timer (WDT) to 8s
MCUSR &= ~(1<<WDRF); // clear the reset flag on the MCUSR, the WDRF bit (bit 3)
WDTCSR |= (1<<WDCE) | (1<<WDE); // configure the Watchdog timer Control Register (WDTCSR)
* Setting the watchdog pre-scaler value with VCC = 5.0V and 16mHZ
* WDP3 WDP2 WDP1 WDP0 | Number of WDT | Typical Time-out at Oscillator Cycles
* 0 0 0 0 | 2K cycles | 16 ms
* 0 0 0 1 | 4K cycles | 32 ms
* 0 0 1 0 | 8K cycles | 64 ms
* 0 0 1 1 | 16K cycles | 0.125 s
* 0 1 0 0 | 32K cycles | 0.25 s
* 0 1 0 1 | 64K cycles | 0.5 s
* 0 1 1 0 | 128K cycles | 1.0 s
* 0 1 1 1 | 256K cycles | 2.0 s
* 1 0 0 0 | 512K cycles | 4.0 s
* 1 0 0 1 | 1024K cycles | 8.0 s
WDTCSR = (1<<WDP3) | (0<<WDP2) | (0<<WDP1) | (1<<WDP0);// Set the watchdog pre-scaler
WDTCSR |= _BV(WDIE); // enable the WD interrupt (note: no reset)
void(* resetFunc) (void) = 0;//declare reset function at address 0
void Going_To_Sleep(){
Serial.println("Sleep");
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // setting sleep mode (full sleep)
noInterrupts (); // make sure no interrupt before sleep
sleep_enable(); // enable sleep mode
EIFR = bit (INTF0); // clear flag for interrupt 0
attachInterrupt(0, wakeUp, CHANGE); // attach an interrupt to pin d2
interrupts (); // interrupts allowed now, next instruction WILL be executed
sleep_cpu(); // activate sleep mode
sleep_disable(); // disable sleep mode (next line of code executed after the interrupt)
Serial.println("Awake");
void wakeUp(){
detachInterrupt(0); //Removes the interrupt from pin 2;
void takeRead(){
Vo = analogRead(ThermistorPin);
R2 = R1 / (1023.0 / (float)Vo - 1.0);
logR2 = log(R2);
T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
T = T - 273.15;
pinMode(lPin, OUTPUT);
pinMode(s1Pin, OUTPUT);
pinMode(s2Pin, OUTPUT);
pinMode(s3Pin, OUTPUT);
pinMode(s4Pin, OUTPUT);
pinMode(rbPin, OUTPUT);
pinMode(pPin, OUTPUT);
pinMode(lbPin, OUTPUT);
pinMode(lgPin, OUTPUT);
pinMode(lrPin, OUTPUT);
digitalWrite(lPin, LOW);
digitalWrite(s1Pin, LOW);
digitalWrite(s2Pin, LOW);
digitalWrite(s3Pin, LOW);
digitalWrite(s4Pin, LOW);
digitalWrite(pPin, LOW);
digitalWrite(rbPin, LOW);
digitalWrite(lbPin, HIGH);
digitalWrite(lgPin, HIGH);
digitalWrite(lrPin, HIGH);
pinMode(interruptPin,INPUT);
for (int i=0; i < 2; i++){
digitalWrite(lgPin, LOW);
delay(800);
delay(400);
delay(5000);
Serial.print("Int. state ");
Serial.println(digitalRead(2));
setupWatchDogTimer();
// digitalWrite(s1Pin, LOW); // config solenoid 1 closed
// digitalWrite(s2Pin, HIGH);
// digitalWrite(s3Pin, LOW); // config solenoid 2 closed
// digitalWrite(s4Pin, HIGH);
// delay(10);
// digitalWrite(s2Pin, LOW);
// digitalWrite(s4Pin, LOW);
// delay(10);
// digitalWrite(pPin, HIGH); // power solenoid
// delay(50);
// digitalWrite(pPin, LOW);
if(f_wdt != 1) { // wait until watchdog has triggered a wake up
return;
Going_To_Sleep();
//////////////////////MAIN CODE/////////////////////////////////
resetFunc(); // call reset
