Hello,
I am hacking apart a slot car track as part of a project to make it controlled by an Arduino Uno. The premise is as follows: two players are prompted for simple math questions, and if they answer them correctly, their respective car goes faster. Currently, I am testing my track driver circuit (PWM pins 5 and 6 connected to TIP120 Darlingtons that then connect to the track) and it is all working beautifully except for one thing:
Sometimes, when the car's speed is at "zero," (PWM output is set to zero), one car (RED in the code, and the only one I am currently testing) moves erratically in tiny bursts, as if for some brief moment it is not actually set to zero. The interesting bit is that I am writing to my motors in an interrupt routine, and this behavior only happens when I set the period of the interrupt to happen at less than 10 milliseconds.
Here is my full code:
#include <TimerOne.h>
#define RedMotor 6
#define YellowMotor 5
#define MinSpeed 150
#define MaxSpeed 220
#define Off 0
#define LOOPDELAY 10
int RED = 0; //Red and yellow PWM values
int YELLOW = 0;
float motor = 0;
float step = 0.05;
pinMode(RedMotor, OUTPUT);
pinMode(YellowMotor, OUTPUT);
randomSeed(analogRead(3));//the only unused analog pin
Serial.println("Beginning Motor driver test.");
analogWrite(RedMotor, Off);
analogWrite(YellowMotor, Off);
Timer1.setPeriod(200);//200 uS
Timer1.attachInterrupt(WriteMotors);
int num1 = random(5);
int num2 = random(5);
int solution = num1 + num2;
Serial.print(num1);Serial.print(" + "); Serial.print(num2);Serial.print(" =? ");
while(Serial.available() <=0)//This loop (decay loop for the speed) needs some delay to function correctly.
motor -= step;
RED = (int)motor;
delay(LOOPDELAY);
int guess = Serial.parseInt();
Serial.println(guess);
if(guess == solution)//check the solution. If it is correct, speed up the car.
motor += 40.00;
Serial.println("Correct! :) ");
Serial.println("Incorrect! :(");
//constrain the motor values to (MinSpeed <= motor <= MaxSpeed)
if(motor < (float)MinSpeed)
motor = MinSpeed - 1.0;//set it to just under the minimum speed so the car stops, but close enough so a correct answer gets it moving again
if(motor > (float)MaxSpeed)
motor = MaxSpeed;
Serial.print("Speed = ");Serial.println(motor);
void WriteMotors()
if(RED > MinSpeed)
RED = constrain(RED, MinSpeed, MaxSpeed);
else if(RED < MinSpeed)
RED = Off;
if(YELLOW > MinSpeed)
YELLOW = constrain(YELLOW, MinSpeed, MaxSpeed);
else if(YELLOW < MinSpeed)
YELLOW = Off;
analogWrite(RedMotor, RED);
analogWrite(YellowMotor, YELLOW);
I appreciate any and all feedback and help. Thank you!
