[RESOLVED] Error: expected constructor, destructor or type conversion???
Hi guys, I’m trying to create the basic library (for learning purposes) below, and I’m getting the following errors:
Error:
[b]expected constructor, destructor, or type conversion before '(' token[/b]
In file included from ReadMPU9150.ino:2:
/Users/kschembri/Documents/Arduino/libraries/MPU9150/MPU9150.h:9: error: expected unqualified-id before 'int'
/Users/kschembri/Documents/Arduino/libraries/MPU9150/MPU9150.h:9: error: expected `)' before 'int'
/Users/kschembri/Documents/Arduino/libraries/MPU9150/MPU9150.h:7: error: an anonymous struct cannot have function members
/Users/kschembri/Documents/Arduino/libraries/MPU9150/MPU9150.h:14: error: abstract declarator '<anonymous class>' used as declaration
ReadMPU9150:5: error: expected constructor, destructor, or type conversion before '(' token
ReadMPU9150.ino: In function 'void setup()':
ReadMPU9150:38: error: 'MPU' was not declared in this scope
The header
#ifndef MPU9150
#define MPU9150
#include <Arduino.h>
class MPU9150
	public:
		MPU9150(int address);
		int write(int address, int data);
	private:
		int MPU9150_ADDRESS;
#endif
The contents
#include "Arduino.h"
#include "MPU9150.h"
MPU9150::MPU9150(int address)
	MPU9150_ADDRESS = address;
int MPU9150::write(int address, int data)
	Wire.beginTransmission(MPU9150_ADDRESS);
	Wire.write(address);
	Wire.write(data);
	Wire.endTransmission(true);
	return 1;
The sketch
#include "Wire.h"
// Define the MPU9150 object
MPU9150 MPU(0x68);
// Define the locations of various MPU addresses
#define MPU9150_PWR_MGMT_1         0x6B
  Wire.begin();
  // Clear the 'sleep' bit to start the sensor.
  MPU.write(MPU9150_PWR_MGMT_1, 0);
I would appreciate any guidance… thank you!
Well, you would be asking for trouble with using the #ifndef thing at the top of the file, with the same name as your class. Usually, you would have some unique name for that, like #ifndef MPU9150_H
You are also asking for trouble, or at least confusion, or maybe obfuscation, by not distinguishing anywhere between the I2C device address, and the device's internal register address.
Oh I see, okay that makes sense. Thanks!
